"Errors occurred while trying to unpack the PIGM file"
Haven't been able to import textures with Skindigo for a while. Anyone else having this issue?
Re: "Errors occurred while trying to unpack the PIGM file"
me too in skindigo for mac
Same here... I have to manually unpack the pigm and then import the igm.
Mac version 3.2.8 only? I will check it out...Voytech wrote:Same here... I have to manually unpack the pigm and then import the igm.
3.2.8 for sure... maybe as far back as the previous beta release as well - can't remember.Whaat wrote:Mac version 3.2.8 only? I will check it out...Voytech wrote:Same here... I have to manually unpack the pigm and then import the igm.
Yeah, it hasn't been working for awhile, but it isn't a feature I use very often so it rarely comes up as an issue.Whaat wrote:Mac version 3.2.8 only? I will check it out...
Heyo, how do you manually unpack a pigm?Voytech wrote:Same here... I have to manually unpack the pigm and then import the igm.
You unzip it !Frutiger wrote:Heyo, how do you manually unpack a pigm?Voytech wrote:Same here... I have to manually unpack the pigm and then import the igm.
CTZn wrote:You unzip it !Frutiger wrote:Heyo, how do you manually unpack a pigm?Voytech wrote:Same here... I have to manually unpack the pigm and then import the igm.
I get similar error message as in this image. When i click search and look for Concrete for instance, it asks me if I want to download the material and when I click yes it brings up a DOS window and tries to unpack and then the error message say that it failed in downloading the material into the project. What am I doing wrong?
This has been bugging me for a while. I would appreciate any help.
Thanks much,
Thanks much,
