SkIndigo 3.2.5 (beta)
Posted: Sun Jan 08, 2012 5:30 pm
A few fixes in this release and a couple improvements. This is a release candidate for 3.2 stable. Requires Indigo 3.2.0.
#Version 3.2.5
#Changed: no longer storing full path for nkdata (fixes nkdata path errors when transferring SKP from Mac to PC)
#Added: Environment Map Quick-Add button
#Changed; displays error message and aborts export if aperture obstacle map is not found
#Fixed: simple UI power slider to work with new emission scale system
#Changed: displays error message and aborts export if aperture image map is not found
#Fixed: bug with white space in Indigo application path on Mac
#Fixed: normal smoothing bug that occurred for first render of some scenes
#Changed: made SkIndigo a SketchUp extension (can now be disabled or enabled without uninstalling/reinstalling)
#Changed: displays warning message if using environment map and light layer is turned off
Please report any bugs and error messages found in the Ruby Console Window.
Note that there is still a normal smoothing bug present in Indigo 3.2.5 but it should be fixed when the next Indigo update is released. This is the bug that causes unwanted smoothing of some faces.
Thanks for testing!
Enjoy!
SkIndigo 3.2.5 Windows Installer
SkIndigo 3.2.5 Mac Installer
#Version 3.2.5
Thanks for testing!
Enjoy!
