Page 1 of 1
Error: Can't find material "default"
Posted: Fri Sep 09, 2011 5:58 am
by Frutiger
This one's fun:
Error while building scene: No such material 'Default'
Anyone else run into this?
Re: Error: Can't find material "default"
Posted: Fri Sep 09, 2011 7:21 am
by Whaat
Frutiger wrote:This one's fun:
Are you using an external mesh?
Can you post the SKP for testing?
Posted: Fri Sep 09, 2011 8:08 am
by alffrad
It happened to me too...
I thought I was doing something wrong, so now every time I change materials or add a component from another file, I try to send it to indigo so I know what maybe causing the problem and I can delete it.
also It happened when trying to "purge unused"
Posted: Fri Sep 09, 2011 8:47 am
by alffrad
Hello Whaat,
Please help me before I go insane.. :roll:
In the Skindigo 3.0.15
I can't:
Netwotk Render
Place Enviroment Maps
Instancing
Is this normal? does this works on 3.0.14?
Thanks a lot!
Posted: Sat Sep 10, 2011 4:26 am
by Whaat
alffrad wrote:Hello Whaat,
I can't:
Netwotk Render
Instancing
Thanks a lot!
Please read the entire first post in the SkIndigo 3.0.15 thread very carefully. :) There were major changes.
Instancing is now handled automatically so don't worry about it.
Environment maps are now handled using Background Materials. Read more in the 3.0.15 thread.
Network rendering works fine for me (no changes were made here). Maybe you were doing something wrong...
I realize that these changes have caused some confusion. I am trying to wrap up some final major changes to SkIndigo 3.0.X and then I plan to create a bunch of tutorials to fully document how to use every feature of SkIndigo 3.0.
Stay tuned... :)
Posted: Sat Sep 10, 2011 4:29 am
by Frutiger
Just external references in this one. Here's a dropbox link to the file (80 MB). Let me know if there's anything else I can do to help, Whaat.
Alffrad, to be fair, I've been able to get all of those things to work after some fiddling. The new workflows threw me for a loop at first, that's all. Network rendering seems to be the least stable of all, but thankfully the least critical to staying operational. That's probably a questions for the Indigo guys.
Posted: Wed Sep 14, 2011 3:50 pm
by alffrad
I understood Instancing in Skindigo 3.0.15, thanks to Pibus here´s the link:
http://www.indigorenderer.com/forum/vie ... 1&start=15
Then I read "again and again" the Skindigo 3.0.15 thread for the Environment Maps until I realized that I had to create a material and add an "EMITTER" to it. Now I don´t understand how to scale it. But anyways If I render with an environment map, Indigo crashes...
Also I post this for the network rendering:
I CAN´T GET IT TO WORK.
http://www.indigorenderer.com/forum/vie ... =5&t=11068
Thanks a lot!
Posted: Mon Oct 03, 2011 4:06 pm
by kwistenbiebel
Ruaaaar... I am running into the same error. Error while building scene: No such material 'Default'
Not sure how I can solve this...
Posted: Mon Oct 03, 2011 4:21 pm
by kwistenbiebel
It's quite urgent that I can solve this :( ...
Posted: Tue Oct 04, 2011 3:31 am
by Whaat
kwistenbiebel wrote:Ruaaaar... I am running into the same error. Error while building scene: No such material 'Default'
I think this is a bug in version 3.0.15. Can you try rendering with SkIndigo 3.0.14 and see if it works?
Posted: Tue Oct 04, 2011 1:09 pm
by kwistenbiebel
Hi Whaat,
Thank you for the reply. I hope you have been well :)
I can confirm it does work in Skindigo 3.0.14 together with Indigo 3.0.12.
Posted: Mon Nov 07, 2011 6:13 pm
by Whaat
This bug should be fixed in 3.2.1 (just released)
