[Solved] Static Skindigo GUI
11 posts • Page 1 of 1
fractal.design
Post by fractal.design » Thu Mar 10, 2011 10:22 am
I recently Installed Sketchup 8 on my Windows 7 64bit machine.
To begin with (If I remember correctly...) everything was fine.
However, now for some reason the Skindigo Gui is messed up.
For the settings window:
All the settings are on one page, which extends far off screen.
Clicking on the individual items on the left has no effect.
Clicking on any setting has no effect.
The material window:
Displays material "Foo"
Nothing is responsive.
Default values are all "Foo"
Could this be because Sketchup 8 has slightlty changed some ruby stuff?
Installing different versions of Skindigo with no success.
What can I do?
Thanks for any help.
Last edited by fractal.design on Sat Apr 09, 2011 8:23 am, edited 1 time in total.
cotty
Re: Skindigo GUI in Sketchup 8
Post by cotty » Thu Mar 10, 2011 6:58 pm
fractal.design wrote:...Could this be because Sketchup 8 has slightlty changed some ruby stuff?
I have installed
- Sketchup 8.0.4811 (free)
- Indigo 2.6.1 (64 bit)
- Skindigo 2.6.1
- on Win7 64 machine
and everything is working correctly. So I don't think it's a ruby problem.
Cotty
Post by Headroom » Thu Mar 10, 2011 11:27 pm
While it may not be a ruby problem, the contents of the ruby console (Window -> Ruby Console) still are of interest in analyzing the problem.
fractal.design
Post by fractal.design » Fri Mar 11, 2011 12:56 am
Nothing in the Ruby Console...
This is very weird. It happens on SU 7 also (with older versions of skindigo too)
I wonder what I have done...
fractal.design
Post by fractal.design » Fri Mar 11, 2011 6:05 pm
Well,
Seeing that the Settings.html file works fine in the browser, I started thinking that maybe I should turn IE8 back on.
Didn't help.
Anyway, here is what it looks like:
fractal.design
Post by fractal.design » Tue Mar 15, 2011 10:45 pm
Are there supposed to be any registry settings under:
"HKEY_CURRENT_USER\Software\Google\SketchUp8\SkIndigo"
or:
"HKEY_CURRENT_USER\Software\Google\SketchUp8\SkIndigoDefaults"
Mine are blank on install and after a run.
Post by Whaat » Wed Mar 16, 2011 6:09 am
Try resetting your IE settings to the defaults and let me know if that fixes it.
Tools->Internet Options->Advanced
fractal.design
Post by fractal.design » Wed Mar 16, 2011 8:00 pm
No success :(
fractal.design
Post by fractal.design » Thu Mar 17, 2011 10:28 pm
Should there be registry settings after install?
What are they?
(Can someone be kind and export them as a .reg for me?)
fractal.design
Post by fractal.design » Sun Mar 20, 2011 2:18 am
Still no luck uninstalling, deleting plugins folder, rebooting, installing, uninstalling applications, rinsing, repeating.
Any clues or tips on what might be causing this behaviour?
fractal.design
Post by fractal.design » Fri Apr 08, 2011 1:30 pm
Awesome, Solved.
I was having other weird issues along with the posted problem:
The Services panel brought up an error everytime i check the services"
One or more activex controls could not be displayed because either...
Searching that problem produced this helpful page: http://social.technet.microsoft.com/For ... b8dba7b000
In short it explains to:
delete 1 extra (parasite) zone from
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\
with pseudo-graphic number, you'll see it before zone number 0.
It seems this is a bug of Adobe flash player update, though I am not sure.
I guess when I installed CS5 it maybe updated the flash player along with it to produce this confusing error.
Sorry Skindigo, I won't loose faith in you again.
