Shadows rendering even though off in Sketchup?
7 posts • Page 1 of 1
Bosseye
Post by Bosseye » Sat Feb 05, 2011 4:35 am
'Lo, me again (I seem to spend a lot of time asking questions on here :o ....)
Very quick one, in sketchup you can set whether an entity casts shadows or not. But regardless of whether the entity is casting visible shadows in Sketchup, Indigo renders a shadow regardless.
Any thoughts on how I stop this? I have a view through a large pane of glass to the building opposite which is just a photo texture on a sketchup box. The photo already has shadows on it so I've set the 'building' entity to not cast shadows as a big square shadow spoils the illusion of the background slightly. So the entity isn't actually casting a shadow, but Indigo is rendering as if it is...
Re: Shadows rendering even though off in Sketchup?
Post by Pibuz » Mon Feb 07, 2011 5:50 am
It is impossible to make an object NOT to cast a shadow, when using Indigo. Every object casts a shadow in the real life, and so it does in Indigo :wink:
I believe this is a "limit" of unbiased renderers in general, but I may be wrong. Kick me if I am.
Bosseye
Post by Bosseye » Mon Feb 07, 2011 9:44 pm
Ha, I can't escape the miserable boot of real life even when working in the virtual world it seems.
Ok, cheers Pibuz. Wasn't vastly important, just curious.
Post by Pibuz » Mon Feb 07, 2011 9:47 pm
Bosseye wrote:Ha, I can't escape the miserable boot of real life even when working in the virtual world it seems.
Indeed, you can. Just use biased renderers :wink:
Soup
Post by Soup » Tue Feb 08, 2011 10:19 am
Set the image plane to emit light, and it won't have a shadow :)
Post by Pibuz » Tue Feb 08, 2011 7:59 pm
..that is a pro trick 8)
Bosseye
Post by Bosseye » Tue Feb 08, 2011 10:08 pm
Soup wrote:Set the image plane to emit light, and it won't have a shadow :)
Hey, now that is cunning.....I'll try it :D
