RBZ:
http://downloads.indigorenderer.com/dis ... 4.10.1.rbz
Windows Installer:
Changelog:
4.4.10.1
Added new fabric material type.
Fixed section plane export resulting in a scene load error.
SkIndigo 4.4.10.1
Re: SkIndigo 4.4.10.1
Hi Ono!
In my case the parameters "Roughness" and "Sheen Weight" of the fabric material set in Skindigo, are not loaded into Indigo, which maintains the default parameters.
Hi OnoSendai,
I purchased Indigo recently, is there any plans to develop the Sketchup plugin so it will be more compatible with Sketchup same like the cinema 4d plugin ... Thanks.
This is working as intended, what's happening here is that you have selected 'SketchUp' in the map drop-down box. This means that the roughness and sheen weight paramaters are using the SketchUp texture map to control their values.
Do you mean an embedded plugin to SketchUp?
That is something we have though about and even experimented with.
