Also no assets that are copyrighted by a a third party. So you have to take care about models & textures!Lal-O wrote:Oooooooohh, i see...now everything makes sense. I apologize for my misunderstanding.
May 2017 Competition
Re: May 2017 Competition
Entering with Heavy Weather (is the title of an old music album too).
158 Kb.
20 min. render.
Indigo´s output Ektachrome 400 XCD.
Rendered in V3.8, with some problems to acquire the same result in v4.0 ...
This circumstance...
In a while I post the results of V4.0
Contains the CTZn´s code for clouds.
158 Kb.
20 min. render.
Just a tip on HDRI's. I keep them at 32bit exr but scale the resolution down to something like 192*128 for example. Keep in mind that the sources for the HDRI's I shoot myself so I know they have all the range which is why I keep color depth over resolution. I usually shoot with 5-7 stops or more if necessary.
That's probably because of the silent change made to result of Indigo's camera tonemappingyonosoy wrote:Rendered in V3.8, with some problems to acquire the same result in v4.0 ...
I´m refering more to the change in the FBM noise section, but you are all right with the tonemapping too.
v4.0.50, because in the last one the obstacle map is broken (so 0,7 MP).
Indigo´s output, with color curves correction.
Pigs size 112 Kb. Update (same picture except the obstacle map) v4.054, so 1 MP.
Pigs file 7.31 KB (the minime).
Super sample 1. Update (spherical cam).
- aleksandera
Hi!
Here's my contribution to the competition.
Pigs. file size: 2.71 MB
Regards,
Aleksander
Regards,
Aleksander
- Polinalkrimizei
Hi guys, this is a quick and dirty entry - just a simple product pic with procedural textures from the database to save some space. Not at all top notch, but perhaps worth a cup ;-)
File size is 440KB.
Looks much better though with Bub's Old White Wall and Oscar's floor, but then it is around 140 MB :-(
EDIT: Render time on a GTX 1060 is about 5 mins, maybe less. Includes light layers (now a little tweaked), HDRI lighting, mesh emitters, and procedural materials that I didn't do myself!
File size is 440KB.
Last edited by Polinalkrimizei on Thu Jun 01, 2017 6:23 am, edited 1 time in total.
- arc en ciel
hi everybody,
a new entry :
OpenCL rendering
pigs file size : 4.94 mb
original model : I did it in Blender3D some years ago, it's inspired by Lambo rambo (model Cheetah) by Lamborghini : LM002
update 31 may - Wellington time : 23h19
update 02
toy lambo in openCL
My ultimate update with scatter function and some corrections !
the super ultimate update with optimizations (instance for wheel), radiocommander changed, ISL fantastic Galinette shader in action : Lambo_glassBead - 4mb pigs
half of the car is instance, simplified subdivisions, simplified shader's car, ameliorated motion blur's effect
06/06 --> HDR changed, cable winch added, smallest file size
11/06 -->complete retopology of the car with compatibility with Indigo's subdivision by 3 or 4, more instances objects, ultra compact 1.4 Mo file pigs
11/06-->Blue paint version, 32 millions of triangles in 1,4 Mo ! and more ... in largeCamera
21/06 --> the front of the vehicle completely remodeled, all ISL removed : twice as fast to calculate
a new entry :
OpenCL rendering
update 02
toy lambo in openCL
- lambo76_sansISL_sol3_rc1.pigs
- (1.36 MiB) Downloaded 512 times
- lambo6-LamboRetop2Sn1dC0g3i3.pigs
- (1.38 MiB) Downloaded 343 times
- LamboRetop2Sn1dC0g2aPlaque_2m_logo-r2_sweet.pigs
- (1.34 MiB) Downloaded 333 times
- lambo_glassBead_cableWinch.pigs
- (2.54 MiB) Downloaded 300 times
- lambo_glassBead_flou_R.pigs
- (3.67 MiB) Downloaded 331 times
- lambo_glassBead_flou.pigs
- (4.04 MiB) Downloaded 325 times
- lambo_glassBead.pigs
- (3.9 MiB) Downloaded 351 times
- lambo_v4Billes.pigs
- (4.97 MiB) Downloaded 335 times
- lambo_v3c.pigs
- (4.89 MiB) Downloaded 338 times
- lambo5mb_v2b.pigs
- (5.03 MiB) Downloaded 361 times
This are my last attempts to get a decent entry to the contest :)
By the way....The sky layer and the satin glass ( that material that comes with Skindigo installer ) are not working when rendering with GPU ... Is that normal ? The satin glass turns dark and the Sky layer simply seems to be off ... ¬¬
- aleksandera
This is an old scene I had started but never finished (original ambition was to place sculpture models from work, Whitaker Studio, in the inner ring, possibly animate, and render spherical/vr). To meet the no copyright I made a few geometric designs and placed them instead.
Tried to run gpu render but my work laptop's gpu, a k3000m & where my work license resides, apparently isn't supported for gpu rendering so this is a cpu + network render.
I believe concrete came from Indigo material database. The rest are heavily modified google searched images or from sketchup.
no post processing on any of the images
Would love a second license to have at home.
Hi all
Here’s my entry for the contest. Inspiration was an old well known painting (at least in Denmark) called The Fisherman. The painting falls under the category trivial art - mass produced art. Supposedly the original painting was painted in 1920 by Harry Haerendel.
My humble interpretation are done in Indigo with GPU in 28 m, 37 s with 15412.87 samples per pixel.
Scene size is 4.05 MB
Cheers Nik
(do a google search on "fisker maleri" to see different versions of the painting)
Cheers Nik
Hello Ladies and gentleman!
Here's my humble mechanical heart for Indigo Render. Model, textures and HDRI by me.
I hope that using Indigo Logo isn't prohibited. ;)
My Submission :
I find few hours ( deadline in work
) and make this FastSSS Scene.
Scene size : =/- 4mb ( i don't know how
) base scene have 500mb
- Super Optimization
Compession level hard.
Render time = Bidirectional path tracing on 4CPU = 4/5 min
Blend layer shader:
Blend using mask + bump map on this mask
Paint - Oren-Nayar with Color map
Skin - FASTSSS
Maps - Color,roughness,fresnel scale, bump, displace
IOR 1.4
Absorption - In this scale 500
Scattering - 4000
HDR - 128 pix
Maps - 128x - 4k
3D model form 3d scanning
Color Texture - 3d form scanning
Mask, Bump, Roughness - Substance Painter
PostPro - Nuke = LUT/GLOW/GRADE - little post.
3 Scene for different angle of view.
Time
23:00 In Poland
Back to work
Blend layer shader:
Skin - FASTSSS
IOR 1.4
Scattering - 4000
HDR - 128 pix
Maps - 128x - 4k
Time
23:00 In Poland
Back to work
Mateusz Sroka
Platige Image - Lighting / Shading / Look Development Artist, Environment Artist
Since better, faster machines are on the horizon I wanted to go full bananas on a simple scene with most adored materials (shaders). But it's either Blender exporter or my lack of experience with it.
Is on display, or it should be :)
Volumetric (fog) and rays (had to limit it, because of the fireflies all over).
Motion Blur on mesh Emitter, precious Metal & dispersed Glass... ? Doesn't appear so?
Using light layers is working nice, tho am wondering if simple animation can be done & exported within Indigo, is there such a plan or How to do it in simple way?
Anyway... imagery done with Indigo is truly sexy...
Thanks all and best wishes to everyone participating.
:D
& Another, classical quickie :)
:D
