export for houdini
Announcements, information, requests and support regarding other exporters and general/new exporters
jiversen
Post by jiversen » Sat Mar 22, 2008 3:48 am
Another couple of questions:
1) the .obj support Indigo has.. I assume that the geometry within those most be triangles too, correct?
2) the renderer termination time that you supply on the commandline - is there a way to rather have that time supplied in the .IGS? and an output image name? if I want to render a moving sequence from indigo, i'll need to supply these and it's most convenient to do so within the .igs itself.
Thanks,
Jason
Post by Kram1032 » Sat Mar 22, 2008 3:52 am
2) well, yes... Every exporter does it... Or should do it.
jiversen
Post by jiversen » Sat Mar 22, 2008 4:45 am
Kram1032 wrote:2) well, yes... Every exporter does it... Or should do it.
Can it? Could you point out to me the renderer_settings for this? I'm looking in the Indigo Manual.pdf and I don't see any settings which would allow me to set this inside the IGS. I suspected other exporters invoked indigo_console with these as arguments.
Indigo on Linux:
I'm now at work quickly trying to run Indigo1.0.8 under wine on SUSE9.3, and unfortunately it complains about "trying to load the C runtime library incorrectly". Anyone have any advice on that?
jiversen
Post by jiversen » Sat Mar 22, 2008 3:11 pm
Sorry- another thing:
It seems as if 1.0.7 will search for the inifile relative to its executable fine, except if you're relying on Indigo.exe being in the search path $PATH.
ie, This works:
%> C:/Users/jiversen/indigo1.0.7/Indigo.exe scene.igs
But this doesn't:
%> set PATH = %path%;C:/Users/jiversen/indigo1.0.7/Indigo.exe scene.igs
%> Indigo.exe scene.igs
..in the second case it fails not being able to locate its inifile.
(I might have the set syntax wrong there, I set it correctly in the Windows Control Panel GUI)
jiversen
Post by jiversen » Sat Mar 22, 2008 6:36 pm
So I've completed a first cut of the pipeline and it's available for download from http://www.sidefx.com/exchange/info.php ... sionid=482
- and you can read more here: http://forums.odforce.net/index.php?showtopic=6405
There are a couple of outstanding things but I think it works, mostly!
Enjoy,
Jason[/url]
Post by OnoSendai » Sat Mar 22, 2008 7:40 pm
jiversen wrote:Another couple of questions:
Thanks,
Jason
No, other polygons are supported in .obj files.
Have a look at the updated manual here:
http://www.indigorenderer.com/joomla/fo ... php?t=3810
The setting you are after is 'halt_time'.
You can't specify the output filename in the scene file though.
Post by OnoSendai » Sat Mar 22, 2008 7:45 pm
jiversen wrote:So I've completed a first cut of the pipeline and it's available for download from http://www.sidefx.com/exchange/info.php ... sionid=482
Enjoy,
Jason[/url]
Cool, thanks for your effort.
I'm looking forwards to some renders!
jiversen
Post by jiversen » Sun Mar 23, 2008 3:57 am
Thanks for the Manual update - I'll support those new parameters shortly. Being able to supply an aperture image is a cool idea, nice one!
jiversen
Post by jiversen » Fri Mar 28, 2008 7:26 pm
Updated to v0.2, which now supports most of the Indigo 1.0.9 specification.
http://forums.odforce.net/index.php?sho ... st&p=45393
http://www.sidefx.com/index.php?option= ... r&Itemid=8
Post by OnoSendai » Fri Mar 28, 2008 7:42 pm
Thanks Jason,
I'll add the link to the main download page.
jiversen
Post by jiversen » Wed Apr 02, 2008 7:31 pm
Updated to v0.3, which now supports a few more entities.
Changes: http://forums.odforce.net/index.php?sho ... st&p=45666
Download: http://www.sidefx.com/index.php?option= ... r&Itemid=8
jiversen
Post by jiversen » Tue Apr 15, 2008 8:26 pm
Updated to v0.4: Indigo v0.4 on the Exchange
Changes and Forum: http://forums.odforce.net/index.php?showtopic=6405
changelog wrote:0.4 - 15 April 2008,
- Added check for bad shader assignments- or regular Houdini shaders being assigned. These will show up RED in renders.
- Modified run_indigo.py to accept -o arg for output filename. Now "ip" renders to default Indigo destination.
- Added Exit Portal support by way of a property "i_exit_portal" (Thank you Kubabuk on odforce.net!)
- Added IES support to MeshLights (untested)
- Misc parm fixes (Thanks vmuriel on odforce.net!)
- Added Crop Window support. Please note that it works well only with Linear Tonemapping.
Still no partitioning yet, unfortunately.. but enjoy anyway.
afecelis
Post by afecelis » Sat Apr 19, 2008 11:38 am
Jiversen, thanks for your great exporter. It really opens lots of possibilities for Houdini and seems very interesting to be tried out.
I got a quick question, does it work on the apprentice/HD edition?
And, is there a quick tutorial on how to get started? A quick howto on creating a basic scene, adding indigo materials, creating a camera, adding the indigo light and setting up the render ;) i think it would come in pretty handy.
Regards,
Alvaro
AMD Ryzen 7 1800 @3.6ghz, 32GB ddr4 3200 mhz Ram, 2X Nvidia Gtx 1070 8GB, Win10/Elementary OS 5.0 Juno (ubuntu 18.04), Blender/Sketchup/Modo/Cinema4d
jiversen
Post by jiversen » Mon Apr 21, 2008 10:37 am
I'm not sure, but I don't think it works with Apprentice - otherwise it would be simple to circumvent the limitations built in to the free edition - and then who'd need to ever buy the commercial edition? You would need one of the commercial licenses - probably Escape and up will all work fine.
As for tutorials, I might be able to throw together simple scenes which demo the various entities much easier than a tutorial. I'll look at the next time I make additions to it. On odforce there are a couple of guys playing with it and they might have scenes to share too.
Take care,
Jason
afecelis
Post by afecelis » Tue Apr 22, 2008 3:57 am
Thanks a lot for your prompt answer Jiversen ;)
I though it would be that way. :( I just bough the HD version and I'm having a blast with it but it's a pitty not being able to use Indigo with this version, though I perfectly understand the point you mention about the apprentice edition's limitations. Well, let's see if I'm able to gather the money for Escape someday, heheheheh ;)
You're doing a helluva job, I was reading the development log of the plugin and it's pretty interesting.
thanks a lot for your contributions,
regards,
Alvaro
