Page 1 of 1
MayaToIndigo_1.0.97 (beta)
Posted: Fri Feb 06, 2009 5:04 pm
by CTZn
This version adds controls for procedural textures. The exporter core was reshaped, right now the code is not optimized but overall functionality is close to maximum I hope:
MayaToIndigo_1.0.97_beta1.zip
Here's another amateur video tutorial which may give you a few hints:
procedurals_With_Maya.avi
I hope you will have fun rendering Maya procedurals with Indigo, I have been finding this rather inspiring.
A proper documentation will come on a later stage, since the interactive GUI (see the 'test' tab) will change the relation between MtI and its users by a great deal.
Though some changes require documentation, this will be adressed shortly. Your questions are welcome, and can become part of a MtI FAQ.
Enjoy.
PS: all Updated links refer to the one above.
Posted: Fri Feb 06, 2009 7:55 pm
by CTZn
updated !
Last minute error woops, corrected bug wich was overwriting existing mti_settings. The user can again specify the default values loaded for the settings by editing manually mti_userPrefs.mel.
Posted: Fri Feb 06, 2009 11:27 pm
by mamoret
Thanks a lot CTZn
I hope I can test this one soon
Posted: Sat Feb 07, 2009 5:09 pm
by CTZn
Thank you mamoret !
Updated: added bump support for glossy_transparent (Maya phong)
You switch from phong to glossy_transparent by checking the
refractions box in the
Raytrace Options parameters
of the shader.
Posted: Mon Feb 09, 2009 7:55 pm
by CTZn
See note in post below
Updated (experimental): redesigned the Indigo Shelf and modified the scripts in a way that allows the user to create MtI settings, edit them and launch the render without having to call the main window once.
Posted: Thu Feb 12, 2009 8:45 pm
by CTZn
Updated:
- Reintroduced nk_data for phong
- Nk_data supports bump and emission.
- glossy_transparent (checking 'refractions' in raytrace options of the phong shader) has precedence over nk_data.
Please note that the previous update was a test (buggy) feature, formerly I was supposed only to add the settings button but I'll generalize the principle. Right now even for the (shelf) 'settings' button to work I used a dirty hack.
I hope to make MtI's initialisation more "interactive" in the future
Posted: Thu Feb 12, 2009 8:57 pm
by CTZn
On a side note, I think the former candidate for a test release is now close to stable. It will not be perfect until a moment, but I think that generally speaking I'm making less a mess of it, I'm starting to feel at ease with some parts; I rewrote them
In the case that you are finding that some features that were used to be present in MtI are not there anymore, please let me know wich. Clearly I'm refering to the 'replace' feature, that was used on phongE nodes, adding a note (text) to them. Now the note system is generalized to all materials (*edit: "now that I'm generalizing it", woops was deactivated too for test version, coming back soon), functionality shifted subsequantly. If you feel that's something that you have integrated in your workflow, again please let me know.
