How to set up and render a basic scene:
So let's say you have a basic scene here, like mine. A couple of polygons and a basic plane.
So you want to render this in Indigo. First thing you have to do is to create a light. Your scene won't render without a light. Now, since Indigo is physically based, you need a 3d object to illuminate your scene.
One thing you might want to consider is render time. The more polygons that you have as lights, the more time the render will take.
So then, let's make a light.
Create a plane about 2 units long by 2 units wide. Position it at an angle, facing the object you want to render
Now, we have to make sure that the light is pointing toward the object, and not away from it. Go to Display->Polygon Components->Normals. Select the plane, and you will see that the normals are facing away from the object we want to render.
To fix this, go to Edit polygons->Normals->reverse
Alright! Now what we want to do is triangulate everything. So, select everything. Go to Polygons->Triangulate. Alright, now that we have that done, we need materials. It's always a good idea to set the light materials last. This is because of some errors in my own exporting code... which I am unable to root out. So, we will assign the other materials first.
So far, only 3 materials are supported- that is, meshlights, phongs, and diffuse.
So, to let's make the diffuse material for the ground plane first. Create a lambert, and change its color.
Great! Now let's make a reflective material for the object
. I'll create a mirror material, just as an example. Assign a phong with the following settings to the object.
Alright. Now lets make the light. What you should know about the lighs is that the incandescene value is infact the blackbody temperature of the object. So, to make an object emit a white-ish light, the incandescense value should be in the middle range. For a dim, reddish light, it should be low, and for a bright, blue light it should be very high.
The next thing you should know is that the material type has to be lambert. The collor does not make a difference, just the incandescene value. So let's assign a lambert with the following properties to the plane/light.
Good. Now, all we have to do is to set the render settings, make a camera, and render.
Open up MayaToIndigo, and go to create->camera. Position the camera anywhere you want.
Finally, go to the last tab on the right, and put in settings like this:
click Generate XML Code and Maya should export, and Indigo should pop up. Happy Rendering
