mayaToIndigo alpha release
haggi
Re: mayaToIndigo alpha release
Post by haggi » Fri Mar 14, 2014 11:25 pm
There is a new release of mayaToIndigo. It is still based on the 3.6 version of Indigo. It now supports:
- IES light profiles
- nk_data for phong shaders
- albedo/emission UI feedback
- tone mapping
- white_points
- camera aperture settings and exposure duration
As before, you can download here: http://www.openmaya.net/openmaya/mayato ... wnload.php
The manual is updated in some parts and I added some example maya files for some features. Would be nice to get any feedback if it works at all on other systems.
Post by CTZn » Wed May 07, 2014 2:28 am
hi
I just downloaded the archive and doc and will get back to you soon.
haggi
Post by haggi » Thu May 08, 2014 3:37 am
Cool! I have a version wich implements a first simple version of ISL. But I'd like to add some more features before I release the next version.
Post by CTZn » Fri May 09, 2014 6:05 am
the module was installed correctly i think (I set the paths from the system variables) but the plugin would'nt load with an error saying that the procedure couldn't be found.
how would i help with sorting the issue ?
haggi
Post by haggi » Sun May 11, 2014 2:00 am
Can you tell me which variables you have set? And you use Maya2014 64bit?
Post by CTZn » Sun May 11, 2014 9:00 am
sorry, full reports are tedious over my phone. i've set the module path from the system variables. the plugin did show up but would not load. I am using maya 2013 64 wich might be the most pressing aspect of the issue.
// Error: line 1: Unable to dynamically load : C:/Users/user/Documents/maya/mayaToIndigo/plug-ins/mayatoindigo.mll La procédure spécifiée est introuvable. // // Error: line 1: La procédure spécifiée est introuvable. // // Error: line 1: La procédure spécifiée est introuvable. (mayatoindigo) //
haggi
Post by haggi » Mon May 12, 2014 8:49 pm
Oh, indeed. I completly forgot to mention in the manual or on the website that the plugin is for maya2014 64bit at the moment. Sorry, I'll fix this with the next release.
Post by CTZn » Tue May 13, 2014 9:58 pm
ok no worries, we'get this around soon !
Post by CTZn » Wed Oct 14, 2015 7:40 am
Hi haggi, I got the plugin running under the same installation setup than before with version 2016 but halted the experience upon error:
# mtIndigoLogger : IndigoEnvironmentCreateTab() #
# mtIndigoLogger : IndigoTranslatorCreateTab() #
polyCylinder -r 1 -h 2 -sx 20 -sy 1 -sz 1 -ax 0 1 0 -rcp 0 -cuv 3 -ch 1;
// Result: pCylinder1 polyCylinder1 //
# mtIndigoLogger : aeTemplateCallback: pCylinderShape1 #
# ui : AEIndigoNodeTemplate #
filterString shader/surface shader/volume postCommand assignCreatedShader %type \"\" %node \"polyCylinder1 pCylinder1\"
# renderLogger : Treelister cmd addToRenderNodeTreeLister( "assignNewMaterialWindow|assignWindowForm|nodeTreeLister1", "assignCreatedShader %type \"\" %node \"polyCylinder1 pCylinder1\"", "Indigo/Materials", "indigo/material", "-asShader", ""); #
# Error: line 1: AttributeError: file <maya console> line 1: 'IndigoRenderer' object has no attribute 'createRenderNode' #
Results that I was not able to assign nor create any mti related shading node.
I peaked at github and saw that you did modifications a couple months ago, does it sum up to an update ? Hoping that you are doing well.
haggi
Post by haggi » Wed Oct 28, 2015 12:11 am
Oh, yes indeed. The createRender node script is needed. Sorry, I'll try to update the archive as soon as possible.
Post by CTZn » Wed Oct 28, 2015 3:04 am
Cool thanks, so far I could do an un-shaded render, that part with the Render View works.
haggi
Post by haggi » Fri Oct 30, 2015 6:32 am
As a workaround you can create the shaders by hand and connect them.
e.g. with mel command:
createNode "inDiffuse";
Then you can assing it to the geomety as usual.
Post by CTZn » Sat Oct 31, 2015 12:36 am
can do, thanks for the tip
Post by Oscar J » Fri Nov 13, 2015 8:12 am
Does this work with Mac? Trying to install it on Maya 2016, but it refuses to acknowledge the .mod file.
Post by CTZn » Sat Nov 14, 2015 3:08 am
For what I can tell it wouldn't work on Mac; mll files and the Indigo SDK shipped with are Windows dynamic libraries. The Mac format for them would be *.so.
