mayaToIndigo alpha release
Re: mayaToIndigo alpha release
Post by CTZn » Wed Oct 28, 2015 3:04 am
Cool thanks, so far I could do an un-shaded render, that part with the Render View works.
haggi
Post by haggi » Fri Oct 30, 2015 6:32 am
As a workaround you can create the shaders by hand and connect them.
e.g. with mel command:
createNode "inDiffuse";
Then you can assing it to the geomety as usual.
Post by CTZn » Sat Oct 31, 2015 12:36 am
can do, thanks for the tip
Post by Oscar J » Fri Nov 13, 2015 8:12 am
Does this work with Mac? Trying to install it on Maya 2016, but it refuses to acknowledge the .mod file.
Post by CTZn » Sat Nov 14, 2015 3:08 am
For what I can tell it wouldn't work on Mac; mll files and the Indigo SDK shipped with are Windows dynamic libraries. The Mac format for them would be *.so.
Post by CTZn » Sat Nov 14, 2015 3:28 am
Have the 'Script Editor' opened, you should be able to learn more about the error. It's a generic Maya tip, that will not help you there.
The other MtI I did was not tested on Mac, at least its MEL installer will not work for you, that must be done manually. Then, I can not guarantee results at all :/
The two exporters may coexist, using the same display name for the renderer in two instances.
Post by Oscar J » Mon Nov 16, 2015 2:20 am
Installation off your .mel file did work actually, and I got the interface inside Maya to work. But export failed completely, and since its so outdated as well I kinda gave up the idea of using it. A shame this one doesn't work either - I have started doing some of my modelling in Alias, which works good together with Maya. Oh well.
haggi
Post by haggi » Fri Nov 20, 2015 3:07 am
It is windows only, sorry.
Post by CTZn » Fri Nov 20, 2015 6:12 pm
Oscar J wrote:Installation off your .mel file did work actually, and I got the interface inside Maya to work. But export failed completely, and since its so outdated as well I kinda gave up the idea of using it.
I'm kind of curious on what step is causing an error on Mac, if you are still around this I wouldn't mind the Script Editor output PM'ed (you may edit it if you want).
zio
Post by zio » Tue Jun 21, 2016 1:45 am
Going here:
http://openmaya.net/openmaya/mayatoindi ... wnload.php
File is missing.
Please correct this, I would like to test latest version.
Another thing, haggi, can you leave instructions on how to compile the plugin?
Or anybody?
CTZn?
previously ior
zio
Post by zio » Mon Feb 26, 2018 8:20 am
Hi haggi,
Iv never been able to test your MtI.
Ill post my thoughts meanwhile when I do.
I tried it once for 5 minutes and it seems it crashed maya.
Ill try ti see it in next month.
previously ior
Tyler
Post by Tyler » Tue Nov 13, 2018 5:48 am
hi everybody,
does someone has the latest version of that indigo plugin for maya?
shrisha
Post by shrisha » Sun Nov 25, 2018 4:13 pm
I would love to test it as well.
zio
Post by zio » Sun Dec 16, 2018 2:18 pm
Get the plugin here:
http://openmaya.net/openmaya/mayatoindi ... o_0.12.zip
Only for maya 2014, 2015, 2016
Ask haggi for an update.
Anybody can compile for latest I think.
I do not have the skills
I do not have time to test it. Anybody?
Keep posting
Tyler
Post by Tyler » Mon Dec 17, 2018 12:10 am
thank you very much Zio!!
i'm gonna test it right away!
