mayaToIndigo alpha release
Tyler
Re: mayaToIndigo alpha release
Post by Tyler » Mon Dec 17, 2018 2:46 am
i have to install maya 2016 to try but what i don't get is i was able to install the 0.11 version on maya 2017..
Tyler
Post by Tyler » Tue Dec 18, 2018 9:27 am
ok, the plugin loads in maya 2016 but unfortunately pointless, it doesn't create a render node when you set indigo in the render settings and then you cannot even create an indigo shader and also not gpu.. tooo bad, i wish a maya plug would be available.
fourzeronine
Post by fourzeronine » Tue Dec 18, 2018 12:04 pm
What I have been doing is setting up my scene's in maya and using alembic to move everything over to c4d which seems to have the best indigo integration. But I agree a decent maya indigo plug-in would be amazing.
Tyler
Post by Tyler » Tue Dec 18, 2018 12:36 pm
yes fourzeronine,
that is what i'm doing too, but all my normals modifiers seems to behave strangely once the file is loaded in c4d, do you have the same issues? all my smooth normals are kinda broken (i'm working with cad files translated to poly).
what i was doing is doing the link with obj or fbx but maybe alembic is better, i'm gonna try that.
fourzeronine
Post by fourzeronine » Tue Dec 18, 2018 2:42 pm
alembic seems to work well. my normals always come over properly. just make sure you click the options box and scroll down and select all the check boxes you need, like UV's and world space.
Tyler
Post by Tyler » Tue Dec 18, 2018 10:33 pm
ok fine, maybe alembic is better then, i'm gonna give it a try
thanks
Tyler
Post by Tyler » Wed Dec 19, 2018 12:49 am
fantastic;) alembic export works perfectly! no more normals issues! THANK YOU
Tyler
Post by Tyler » Fri Dec 21, 2018 12:50 am
just a question, how do you manage with abc files to apply materials on different faces selections made in maya?
Tyler
Post by Tyler » Fri Dec 21, 2018 1:46 am
ok, i think i got it, you have to make the object editable, right?
