Cindigo Wishlist
- pixie
Re: Cindigo Wishlist
until it arrives you can use an expresso script so that the polygon size is dependent of the light size.
- light.rar
- (94.71 KiB) Downloaded 98 times
Many thanks. And I really forgot about the complexity of adjusting the intensity of light sources. Success in development!
what would be nice is a "hidden from reflections" and "hidden from refactions" in objects and most of all for lights
- pixie
When exporting an animation I wish I could choose if textures were to be baked just once, and not on each frame. I remember once we had the camera export option where if it on, it would take into consideration and massively speed the export time.
Wish to have r21 version and node framework support
https://developers.maxon.net/docs/Cinem ... _impl.html
I'm sorry for my bad English
- thesquirell
The dragons are coming, don't worry!
As for the nodal support, dunno about that.
wishlist:
1. fog (volumetric lights)
2. 100% gpu denoising (now cpu + gpu as i see)
3. network rendering by frame for every node (now one-frame rendering for all nodes only implemented as i see)
4. command line exporter from c4d to igs file (it could be good if render starts without cinema 4d loading)
Save fast preview
Button for save IPR window would be nice. I found some solution by screenshot app, but better if it would be integrated in C4D
I recorded it.
https://youtu.be/7c1oMupqDlE
I recorded it.
Re: Save fast preview
I added a ticket for this. It will be done (eventually).pavoda wrote: ↑Wed Apr 22, 2020 11:28 amButton for save IPR window would be nice. I found some solution by screenshot app, but better if it would be integrated in C4D
I recorded it.
- pixie
My take would be to take multiple full sized screen screenshots, and afterwards crop it on photoshop, and export the layers to files.pavoda wrote: ↑Wed Apr 22, 2020 11:28 amButton for save IPR window would be nice. I found some solution by screenshot app, but better if it would be integrated in C4D
I recorded it.
La mia idea sarebbe quella di prendere più schermate a schermo intero, e poi ritagliarle su photoshop, ed esportare i livelli in file.
+1
A button to Save Image or Send it to Picture Viewer is standard with IPRs/VFBs of other supporting engines.
I've added this for the next build.pavoda wrote: ↑Wed Apr 22, 2020 11:28 amButton for save IPR window would be nice. I found some solution by screenshot app, but better if it would be integrated in C4D
I recorded it.
