Cindigo 1.1.18 - stable RC1
Post by fused » Sun Mar 08, 2009 9:14 am
for Indigo 1.1.17 and Indigo 1.1.18
download exporter:
Pc Version
Mac Version - no mac version available yet!
PC version contains plugins for R10(32 and 64 bit) and R9(32 bit). (R9 users will have to rename the "cindigo.cdl_R9" to "cindigo.cdl")
Make sure you have the newest version of quicktime installed! Previews will not work with the 64 bit version bacause of the lack of 64 bit quicktime.
Good beginner tutorials can be found here (german and english, a bit outdated)
a big "thank you" goes out to PureSpider, who did a great job and coded lots of useful stuff for this release!
changelog wrote:Cindigo 1.1.18 (stable RC1):
* move to Indigo Utils v2
* fixed emission import
* solved memory problems (normal array wasnt freed after mesh export) (fused)
* rewrote igm import, now using Indigo Utils (fused)
* wrote load function for indigo path and itegrated it into the gui (fused)
* changed load and save functions internally, indigo path is now saved in the settings.cfg (pSr)
* changed a few defaults (aperture shape, ssf, etc.) (fused)
* added random seed (pSr)
* reworked mesh and instance export, (hopefully) fixed all related bugs and added support for nested instances (fused)
* Indigo Instance now shows bounding boxes of child elements (fused)
* Material hepler is now an object instead of a tag. Changed all functions according to that (fused)
* added own object for imported/converted materials and moved all converted materials to a single group, even on multiple material converts (pSr)
* export dialog remembers the last settings (pSr/fused)
Do you like Cindigo?
If you think its valueable software, please feel free to donate.
Please split the donation in two and donate the other half to Indigo.
Cindigo 1.1.18_2.zip
Cindigo 1.1.18_2 PC
(6.07 MiB) Downloaded 370 times
Onfame
Post by Onfame » Sun Mar 08, 2009 9:36 am
Great, thank you very much :)
Edit: Found a problem while i was trying to import the Rubber (blue) Material from the Material-DB.
Stromberg
Post by Stromberg » Sun Mar 08, 2009 9:56 am
From what i have tried it works great :)
Good job :wink:
Post by fused » Sun Mar 08, 2009 10:53 am
Onfame wrote:Great, thank you very much :)
yeah, there are a few materials that arent importing properly.
Post by Zom-B » Sun Mar 08, 2009 2:26 pm
awesome... finally :-)
I'll check out in April ;-P
Post by OnoSendai » Sun Mar 08, 2009 2:58 pm
I will update the Indigo utils code very soon, which should solve these problems.
Camox
Post by Camox » Sun Mar 08, 2009 3:32 pm
Great... Thanks fused ! :D
Post by fused » Sun Mar 08, 2009 4:42 pm
update! this should fix all import problems.
also, i proudly present the first 64-bit version of cindigo (R10 only)!
have fun!
changes wrote:* move to Indigo Utils v2
Post by CTZn » Sun Mar 08, 2009 9:54 pm
Congratulations, fused and PureSpider !
tungee
Post by tungee » Sun Mar 08, 2009 10:25 pm
Thank you Fused, will test it today! :P
Onfame
Post by Onfame » Mon Mar 09, 2009 1:58 am
it works perfectly now, thank you both so much :)
Phoenix
Post by Phoenix » Mon Mar 09, 2009 3:55 am
Thanks a lot Fused, also for the 64 bit version! :D
I'll try it soon.
iacx
Post by iacx » Mon Mar 09, 2009 5:30 am
Fused many thanks, very good version for 64 bit! Great :D
c 4
Post by c 4 » Mon Mar 09, 2009 5:46 am
fused and PureSpider - thank you very much for all the work you have put into this !
One little problem: I have a complex model (with parametric stuff, lots of instances and symmetry, possibly booleans) that I wanted to test with the new version.
I renamed cindigo.cdl_R9 to cindigo.cdl
I choose to convert all materials, selected the path to indigo 1.1.17 and selected start indigo.
Then pressed export and Cinema 4D R9.102 crashed reproducible.
A mesh folder has been created containing 4 igmesh files, but certainly not all geometry (why can't I open the mesh files in cinema like in the earlier versions ?).
Any idea ?
Post by pixie » Mon Mar 09, 2009 8:03 am
Nags:
on materials, when one select preview it always get the same default parameter and isn't saved as for example export dialog. If one press enter it cancels instead of proceeding...
When importing igm, it would be nice to select only from igm and pigm filetype instead from having to chose from all files.
Probs:
If verbose is set to false there's no preview.
Shaders in imported igm's doesn't apply.
Users browsing this forum: BLEXBot [Crawler] and 1 guest
