Well the Cinidigo export scaling parameter is set to 0.01 by default
I've been using a 0.1 value, and it seems this is too small and causes a rendering artifact as shown here
http://www.indigorenderer.com/joomla/fo ... 4818#24818
when I use a scaling of 1.0 - no more artifacts in render
so I think you should set to to 1.0 by default...
Cinidigo scaling parameter....
actually you should model your scenes in idigo units. 1 unit = 1 meter in indigo.
global scale is for ppl like me who like it big. if you model your scenes in real scale you should use the factor 1.
1.0 by deafault will be in the next version.
edit: read that other thread. now everything makes sense...
Users browsing this forum: No registered users and 86 guests
