Specular material help
Marcofly
Post by Marcofly » Sat Jun 23, 2007 9:03 am
not strange, fused.. i always have to hand-edit the .igs to have strong coloured glass mats. just thought that ZomB had already pointed it..
BTW: is it getting better? hope that your presence here means you are healthy and fit again! :wink:
ciao!
Post by fused » Sat Jun 23, 2007 9:17 am
yes, much better. i know that issue.
its strange that settin unit to km helps....
Post by Kram1032 » Sat Jun 23, 2007 9:30 am
why it's that strange?
absorbtion works like that.
the thicker something is, the more it absorbs.
I don't want to repost the milk-example xD
manitwo
Post by manitwo » Sat Jun 23, 2007 9:45 am
Kram1032 wrote:why it's that strange?
:lol: :lol: :lol: why the settings are strange?
do you have a "milkglass" with a diameter of several km at home?
btw, as fused is a exporter-writer i think he knows what absorption is.
Post by Kram1032 » Sat Jun 23, 2007 10:09 am
he said
its strange that settings unit to km helps....
THAT'S not strange.
However, it IS strange, that there is NEED of those sizes. There are whole Mountains, that can be modelled that way xD
Labello
Post by Labello » Sat Jun 23, 2007 10:54 am
fused wrote:strange...
yeah thats true. if i change this factor is always get completely different materials. even with small amounts of increasement
Post by fused » Sat Jun 23, 2007 8:57 pm
maybe i understood sth worng. do you mean you changed the global scale parameter or did you change the c4d internal unit settings from m to km?
if the last is true then its really strange...
edit: and yes i do know what absorption is.
okazaky
Post by okazaky » Sat Jun 23, 2007 9:45 pm
I changed the units setup in Cinema 4D from centimeters to kilometers (the result of this test is the image with the three different scaled spheres)
Now I switched the units back to centimeters and increased the global scale factor in the indigo scene settings tag of your exporter from 0.01 to 0.1 and it works fine now, even in centimeter units.
Is there any specific reason why the default value is at 0.01?
regards,
okazaky
Post by Kram1032 » Sat Jun 23, 2007 9:49 pm
uhm, I guess, 'cause 0.01 = cm ;)
0.1 = dm, so everything is sized 10 bigger.
ok, now, I understand, why you think, that it's strange, fused. :)
Post by fused » Sat Jun 23, 2007 11:51 pm
okazaky wrote:Is there any specific reason why the default value is at 0.01?
uhm, no :)
i always thought the unit settings dont have any effect on the scale. good to know...
Post by Kram1032 » Sat Jun 23, 2007 11:53 pm
oook.... slowly, I get confused. why shouldn't they?
