Indigo for Cinema 4D 4.2.22 - R20 Beta
Re: Indigo for Cinema 4D 4.2.22 - R20 Beta
Post by fused » Tue Nov 20, 2018 12:57 am
pixie wrote:
Sun Nov 18, 2018 11:01 pm
Could you put a switch in the light tag so that one could choose between a diffuse/null material? I usually use it so I can better hide the shadows in some fill light I create in a scene. This way the object emitting light don't have it's own shadow casted.
I put it in the bugtracker.
pixie wrote:
Mon Nov 19, 2018 11:59 pm
One cannot generate IES previews
Error: Failed to create render output directory: Failed to create directory 'C:\Program Files\MAXON\CINEMA 4D R15\plugins\Indigo for Cinema 4D\preview\renders': Access is denied. (code 5)
Yeah IES previews need an overhaul tbh :) Put that in the bugtracker too
arc en ciel
Post by arc en ciel » Mon Nov 26, 2018 1:42 am
hi,
importing .pigm file in C4D R19 is not correct in some cases.
by example : from Online Material Database download "Matte Terracotta Octagon with Glazed Diamonds" (the first one)
save it in .pigm
try to link it using a material type external in C4D, the images are not present
try to import it using import function provided by the plug-in Indigo for C4D 4.2.22, the same, the images are missing
try to re-import this .pigm in Indigo standalone, all is fine.
in C4D, importing this material is partially correct in .igm file format, image in color is present but image in Roughness/Exponent is missing
I suppose, it's related to Roughness/Exponent when an image is in ths channel because I tried an other mat whithout image in the channel --> it's working correctly
Silverwing
Post by Silverwing » Mon Nov 26, 2018 11:20 pm
Hi there and thanks a lot for the R20 update :-)
As always I want to bring to attention that in the C4D plugins there are certain things not working that I consider essential for me to be using this renderer on a daily basis. I do not want to offend anyone here. I just made it my mission to fight for those features ;-)
Please see the linked topic I took the time to write and explain why the certain features are so important for me:
https://www.indigorenderer.com/forum/vi ... 76#p142143
Thanks for your time in advance!
You don´t dream in cryo.
Post by pixie » Thu Dec 06, 2018 9:59 pm
Could we have a defined shortcut key for refreshing IPR? It could be used as a mid step solution until fully refresh is attained.
arc en ciel
Post by arc en ciel » Wed Dec 12, 2018 1:47 pm
It seems like,
in specular material,
in internal medium,
in RGB value of absorption spectrum --> the color values ​​are changing
EDIT : oups !
I just realized than 0 in C4D is equal to 1 in indigo :mrgreen:
... but the result color is different
Post by pixie » Wed Dec 12, 2018 9:14 pm
It is inverted in indigo, in cinema is more user friendly! :)
Post by pixie » Thu Mar 21, 2019 11:52 am
In R20 at least, one cannot make use of LOD. It would be cool for huge scenes, as it would be nice if one could have the size of the export baking size view dependent. That way we could have small texture for small objects far away taking no time and only those close taking a bit more time to bake.
thesquirell
Post by thesquirell » Sat Sep 07, 2019 3:57 am
New R21 released, time for the new Cindigo! :D
