Page 1 of 1
Realtime preview doesn't work anymore
Posted: Fri Jun 02, 2017 12:12 am
by zeitmeister
Hey there,
I noticed that case from time to time. I've got a scene here which doesn't startup in the realtime preview window.
I added the scene into a new one, no chance. I emptied the quickrender folder, no luck.
Restarted the computer, the same.
What else can I do? Which prefs or folders do I have to clear or delete to get it working again?
C4d R14, Cindigo 4.0.48, Windows 7.
Thanks in advance!
Re: Realtime preview doesn't work anymore
Posted: Fri Jun 02, 2017 12:26 am
by zeitmeister
Edit: Same with latest Cindigo 4.0.51
Posted: Fri Jun 02, 2017 2:34 am
by OriginalplanĀ®
Hmmm.... in Cinema IPR works well on Mac.
Cinema Update??
Posted: Fri Jun 02, 2017 4:08 am
by zeitmeister
No, it's always okay to a certain point. It works in new scenes. But at some point, it stops working in a certain scene. Now it doesn't export to Indigo GUI anymore.
I guess I have to import object by object into a new scene to figure out what's happened.
Posted: Fri Jun 02, 2017 7:56 am
by burnin
IIRC - It could be (& most likely is) a missing texture problem (path changed, either moved or removed) since Indigo doesn't communicate with Cinema's Texture Manager you will get no errors, but simply no action, no response. In such case, only manual check & fix works.
Posted: Fri Jun 02, 2017 5:33 pm
by zeitmeister
Supposed that... thank you! Didn't change anything there consciously...
Posted: Fri Jun 02, 2017 10:55 pm
by fused
Thanks burnin, will fix.
