Indigo for Cinema 4D 4.0.43.2
arc en ciel
Re: Indigo for Cinema 4D 4.0.43.2
Post by arc en ciel » Tue Sep 20, 2016 10:13 am
hello,
in C4D where can I setup the rotation of the environnement texture ?
thank's
Post by Zom-B » Tue Sep 20, 2016 6:06 pm
arc en ciel wrote:in C4D where can I setup the rotation of the environment texture ?
In the Indigo environment tab you simple set a sky object, so Indigo can grab the rotation information of this object :)
arc en ciel
Post by arc en ciel » Tue Sep 20, 2016 10:23 pm
:D danke schon
arc en ciel
Post by arc en ciel » Thu Sep 22, 2016 3:11 am
Hello,
it would be nice to have entries for parameters in the ISL code editor. :idea:
Post by fused » Thu Sep 22, 2016 4:00 am
arc en ciel wrote:Hello,
Did a bit of work on that already. Soon, hopefully :)
lenogre
Post by lenogre » Fri Sep 23, 2016 9:32 am
Contegufo : since c4d17, we got a new metaball option.
Accurate Normals : If this option is enabled, internally accurately calculated vertex Normals will be applied that make a more even shading possible in most cases. Note that the Metaball object cannot be deformed because the vertex Normals will then no longer be accurate.
We now need less subdivisions for a better result.
C4D 15 studio - MOI3D - France
Post by Zom-B » Fri Sep 23, 2016 9:50 am
Thanks for the info lenogre, I learned something new :)
contegufo
Post by contegufo » Fri Sep 23, 2016 7:39 pm
@lenogre
Thanks for the information; This can be a good compromise.
Ilay
Post by Ilay » Thu Sep 29, 2016 2:09 am
Hello
Try such solution - http://www.indigorenderer.com/forum/vie ... 10&t=13267
arc en ciel
Post by arc en ciel » Thu Sep 29, 2016 11:39 am
Hello
Brilliant :idea: :arrow: Really cool :!: Exactly the same script haha :D
спасибо
nejck
Post by nejck » Thu Sep 29, 2016 7:29 pm
Hey everyone!
I've got a pretty uncool problem and I'd appreciate some help. I just installed the 4.0.32.2 RT for c4d and whenever I select either my R9 390 or my 4790k CPU as the OpenCL device my cinema 4d crashes like there is no tomorrow.
I have the latest drivers, I have the OpenCL SDK. No idea why it crashes as it just says that it crashed - no reason specified.
Any ideas?
Oh and I also tried a couple of older versions too!
Originalplan®
Post by Originalplan® » Fri Sep 30, 2016 12:40 am
nejck wrote: my cinema 4d crashes like there is no tomorrow.
Hey nejck. I assure you there is tomorrow whether we like it or not. :lol:
Which c4d build are you on? R17.053 (RB166656) ?? If no.. update it.
If that does not fix the issue wait for a never build.
nejck
Post by nejck » Fri Sep 30, 2016 12:42 am
Aye, everyone is testing this thing out and I am on sidelines so I'm pretty sure its not a general issue anyway :)
Not sure about what version my R17 is but I do know its the latest update. Funkily enough, R18 has the same exact issue.
It almost seems like something else is wrong here...
dp3d
Post by dp3d » Fri Sep 30, 2016 5:08 pm
Hi Everyone, I'm new to Indigo, from vrayc4d :). I have very stranger bug on my new PC, Cidingo not load with any C4D shader:, noise, gradient, etc, my VrayC4D, alpha-corona work normal. I have 3 machine to test this bug.
1. Dual Xeon, K4000, win7x64 work OK both 3.8.1.2 and 4.0.43.2
2. i7 6700K, Zotac GTX 1080, board Asus Z170 Pro Gamer, Win10x64: work Ok with 3.8.1.2 and 4.0.43.2
3. i7 6700K, Zotac GTX 1080 Extreme, board Asus Z170 deluxe, Win10x64 work Ok with 3.8.1.2 but not load Shader with 4.0.43.2
all machines are fresh install. I've try to reinstall Visual C++ redistributale all version,2005, 2008, 2010, 2012, 2013, 2015...still not work :d, dont know why :D
Thanks
Shader not work when render
Shader not load in Material Preview, but show on Cube
Post by Zom-B » Fri Sep 30, 2016 11:59 pm
Hey dp3d,
cindigo bakes all c4d shaders, works fine for me.
maybe c4d isn't able to save the temporary backed textures to the HDD because of some fancy user right bla bla, thats the only reason I could imagine :?
Users browsing this forum: BLEXBot [Crawler] and 1 guest
