Indigo 2.2.11
Indigo 2.2.11
Post by OnoSendai » Fri Dec 11, 2009 5:14 pm
Another attempt at fixing the locale (comma) issues, let me know if this works.
Indigo for Linux 32-bit:
indigo_v2.2.11.tar.gz
Indigo for Linux 64-bit:
indigo_x64_v2.2.11.tar.gz
Indigo for Windows 32-bit:
IndigoRenderer_2.2.11_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_2.2.11_Setup.exe
Indigo for OS X 32-bit:
indigo.osx.2.2.11.zip
Changelog:
2.2.11:
* Fixed bug where opening .pigs would sometimes select the wrong .igs file.
* Another attempted locale fix
EDIT: updated 32 bit build to fix mat editor, added 64 bit build.
SzLaszlo
Re: Indigo 2.2.11
Post by SzLaszlo » Fri Dec 11, 2009 11:25 pm
OnoSendai wrote:Another attempt at fixing the locale (comma) issues, let me know if this works.
Changelog:
2.2.11:
linux 64bit ?
drBouvierLeduc
Re: Indigo 2.2.11
Post by drBouvierLeduc » Sat Dec 12, 2009 12:05 am
SzLaszlo wrote: linux 64bit ?
+1 (please !)
Re: Indigo 2.2.11
Post by OnoSendai » Sat Dec 12, 2009 12:10 am
Try it anyway :)
drBouvierLeduc
Re: Indigo 2.2.11
Post by drBouvierLeduc » Sat Dec 12, 2009 12:54 am
indigo 32-bit complains about a missing library (libgomp.so.1) wich is yet installed on my system. Tried to copy this file in the /usr/lib32 folder, but it still doesn't work.
Sorry, I cannot give feedback about this locale problem without 64-bit version.
Josh
Re: Indigo 2.2.11
Post by Josh » Sat Dec 12, 2009 3:43 am
Runs under 32bit, locale problem seems to be solved, as far as I could check quickly. Will do some tests later.
Thank you guys :D
Edit: Material editor still suffers from the same bug.
rendigo
Re: Indigo 2.2.11
Post by rendigo » Sat Dec 12, 2009 2:05 pm
I don't know if this is a linux specific problem but there seems to be a problem with running network slaves finding nkdata:
Indigo Renderer v2.2.11, Linux 32-bit Release build.
Licence not verified, running in free mode.
Scene file path: './cache/network_cache/3837815674/scene.igs'
Loaded energy loss compensation curve from disk cache.
Indigo Driver Exception: SceneLoaderExcep: Error while parsing DiffuseTransmitter material: ComplexIORExcep: ComplexIORDataSetExcep: Failed to open file 'nkdata/cr.nk' for reading.  (In element 'phong', around line 331, column 9)
Will try a Windows network client later and see if the same error occurse there too.
    rendigo
    Re: Indigo 2.2.11
    Post by rendigo » Sat Dec 12, 2009 7:32 pm
    Allright, the Windows network client works just fine, so there seems to be a Linux related issue with finding nkdata. I will try other nkdata later this weekend and report.
    Other than that I want to express how much I like Indigo after (still mostly) playing around with it.
    amadex
    Re: Indigo 2.2.11
    Post by amadex » Mon Dec 14, 2009 1:16 am
    Still no Mac OS X simultaneous version on each update... Why that? I've paid for the license the same as windows or linux users!... :(
    eman7613
    Re: Indigo 2.2.11
    Post by eman7613 » Mon Dec 14, 2009 10:08 am
    amadex wrote:Still no Mac OS X simultaneous version on each update... Why that? I've paid for the license the same as windows or linux users!... :(
    To be fair, this and 2.2.10 are trying to fix a bug in linux, not in M$ or OSX
    Re: Indigo 2.2.11
    Post by OnoSendai » Mon Dec 14, 2009 10:12 am
    rendigo wrote:I don't know if this is a linux specific problem but there seems to be a problem with running network slaves finding nkdata:
      Linux uses case sensitive paths. It should be nkdata/Cr.nk.
      Re: Indigo 2.2.11
      Post by OnoSendai » Mon Dec 14, 2009 10:42 am
      Re: Indigo 2.2.11
      Post by OnoSendai » Mon Dec 14, 2009 3:40 pm
      EDIT: added windows build.
      SzLaszlo
      Re: Indigo 2.2.11
      Post by SzLaszlo » Mon Dec 14, 2009 6:28 pm
      Yes ,yes ,Its work ( ubuntu linux 9.04 -64bit , blendigo 2.2.9 )
      Good "light layers" ,good "update images"
      - 1 question : the emit mesh can't work ( I can see the emit mesh layer in the indigo light layers , but I can't see the light power )
      , only can work with ies profile ?
      rendigo
      Re: Indigo 2.2.11
      Post by rendigo » Mon Dec 14, 2009 10:05 pm
        Yup, I figured it out last night - didn't have time to report, deadline coming up, cringe!
        Thanks though for the help.
