Indigo 1.1.14
Indigo 1.1.14
The big change here is the introduction of the BVH (Bounding volume hierarchy) to replace the BIH. The BVH is generally a lot faster in terms of rendering speed than the BIH (> 80% the speed of the kd-tree), while preserving the same low memory usage and build times of the BIH.
The BVH still builds low quality trees in some circumstances, resulting in low rendering performance , such as the Cornell box scene, but generally it's pretty fast. This will hopefully be fixed in future.
Let me know any performance results, especially comparing the BVH to kd-tree on different scenes.
Switching between the BVH and kd-tree will be done with the bih_tri_threshold setting. (Which is now a misnomer)
32 bit:
http://www.indigorenderer.com/dist/indigo_v1.1.14.zip
64 bit:
http://www.indigorenderer.com/dist/indi ... 1.1.14.zip
changelog:
1.1.14
* fixed fmod linking in ISL
* added OpenMP Dll + manifest to distributions
* replaced BIH with BVH
32 bit:
64 bit:
changelog:
1.1.14
Thanks Ono.... speedups are always very welcome
***EDIT***
OK, now I get it... so Heavy Poly (displacement+subdivision) will benefit from this...
Any numbers how much BVH is faster than BIH for rendering?!
***EDIT***
- PureSpider
Hope that got things clear<@PureSpider> will only the build speed be faster or render speed in general?
<+CTZn> both if I understood ok
<@OnoSendai> of what vs what?
<@PureSpider> BVH vs "normal" kd
<@OnoSendai> build is faster, render is slower
<@PureSpider> eeeeeh :@
<+CTZn> ah, necessarily slower ?
<@OnoSendai> yes
<+CTZn> ok, good to know
<@OnoSendai> ok, in some cases it may be faster
<@OnoSendai> render speed: kdtree > BVH > BIH
<@OnoSendai> mem usage: kdtree > BVH = BIH
- Borgleader
@ono: couldnt find out what the uv set name was, so i rendered it with SSS. im not even sure if there is any...
doubt this is of interest for you, but i find 60s for 28million poly very exciting
Building Mesh 'lucy.ply'...
14027870 vertices (321.072 MB)
28055737 triangles (749.169 MB)
BVH::build()
Calcing root AABB.
Done.
Root AABB min: (225.841080,-388.417145,-605.892822)
Root AABB max: (1155.670166,145.354340,991.145996)
Sorting...
Done (8.44906 s).
Allocating intersect triangles...
Done. Intersect_tris mem usage: 963.217 MB
Build Stats:
Total nodes used: 9408392 (574.243 MB)
Total tri indices used: 37624372 (143.526 MB)
Num sub threshold leaves: 9408272
Num max depth leaves: 120
Num cheaper no-split leaves: 0
Mean tris per leaf: 2.981991
Max tris per leaf: 5
Mean leaf depth: 23.645914
Max leaf depth: 63
Finished building tree.
Done Building Mesh 'lucy.ply'. (Time taken: 60.20800 s)
- im1225838398.jpg (390.2 KiB) Viewed 18104 times
