Indigo 1.1.3
Indigo 1.1.3
Post by OnoSendai » Wed Jun 11, 2008 1:45 am
Hi all,
Another small release, just fixing bugs and tweaking the new embedded mesh format.
32 bit:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
changelog:
1.1.3
* changed embedded_2 format yet again
* changed default name of pigm/pigs in save dialog to be same as igm/igs
* --unpack now doesn't overwrite existing files, and can unpack to absolute paths
* packing packs displacement maps now
* fixed crash on exposition of UV set without providing actual UV data.
* fixed --unpack to make subdirs properly
* new version 2 of IGI format: added render time.
* total render time and samples/sec now displayed correctly when a render is resumed.
* added command line tonemapping with the --tonemap option
* reenabled optional specification of vertex shading normals in the scene file
* reenabled fatal error on non unit-length normals.
* added merge_vertices_with_same_pos_and_normal option for mesh, defaults to true.
* removed step_null_blend option, added step_blend option for blend materials.
The embedded_2 format looks like:
<mesh>
		<name>mesh2</name>
		<normal_smoothing>true</normal_smoothing>
		<embedded_2>
			<expose_uv_set>
				<index>0</index>
				<name>albedo</name>
			</expose_uv_set>
			<used_material_name>mat_a</used_material_name>
			<used_material_name>mat_b</used_material_name>
			<v p="-1.5 0 0" />
			<v p="-1.5 0 2" />
			<v p="1.5 0 2" />
			<v p="1.5 0 0" />
			<uvs uv0="0 0" uv1="0 0" />
			<uvs uv0="0 1" uv1="0 100" />
			<uvs uv0="1 1" uv1="100 0" />
			<uvs uv0="1 0" uv1="100 100" />
			<t v="0 2 1" uv="0 2 1" m="0"/> <!-- this triangle uses mat_a -->
			<t v="0 3 2" uv="0 3 2" m="1"/> <!-- this triangle uses mat_b -->
		</embedded_2>
	</mesh>
manitwo
Re: Indigo 1.1.3
Post by manitwo » Wed Jun 11, 2008 1:52 am
OnoSendai wrote: * total render time and samples/sec now displayed correctly when a render is resumed.
finally :P
thanks ono :)
Post by OnoSendai » Wed Jun 11, 2008 1:54 am
hehe, yeah that issue took a while to fix :)
Post by CTZn » Wed Jun 11, 2008 2:14 am
Thanks !
cpfresh
Post by cpfresh » Wed Jun 11, 2008 2:17 am
Great update Ono, thanks!
Pinko5
Post by Pinko5 » Wed Jun 11, 2008 2:25 am
Tnx ONO!
Luca ;)
Post by PureSpider » Wed Jun 11, 2008 2:26 am
Finally the render times :>
aleksandera
Post by aleksandera » Wed Jun 11, 2008 2:30 am
aleksandera
Post by aleksandera » Wed Jun 11, 2008 2:47 am
Blendigo 1.1.1, simple cube and sun scene.
Error copy.jpg (34.03 KiB) Viewed 5656 times
palawat
Post by palawat » Wed Jun 11, 2008 3:10 am
Does that refer to the situation when one did run Indigo on slave with resume file path?
The reason I ask is that, I tried <indigo.exe scene.igs -r scene.igi -n s -h hostname:7777> on slave which make Indigo on the master box kinda confuse and wrongly display total render time and s/pix. Nowadays I use <indigo.exe -n s -h hostname:7777> on slave.
When you said it's been fixed, that kinda makes me thinking I might have used the improper command for the whole time. Which one should I use to resume rendering on slave?
Sorry, if it looks like I'm panicking. I really DO.
:shock:
Cheers,
Post by Kram1032 » Wed Jun 11, 2008 3:14 am
thanks :D
Post by OnoSendai » Wed Jun 11, 2008 3:20 am
:shock:
You should only use the resume '-r' command on the master indigo process.
palawat
Post by palawat » Wed Jun 11, 2008 3:56 am
I see.
Thank you very much, Ono. The panicking is out, now.
Cheers,
Kosmokrator
Post by Kosmokrator » Wed Jun 11, 2008 4:08 am
respect..............to the MASTER!!!!!!!!!!1
Post by CTZn » Wed Jun 11, 2008 7:50 am
What should I do in order to render a cube with sharp edges ? It's confusing because you define geometry normals and Indigo seems to loose them... is that because of merge_vertices_with_same_pos_and_normal ?
edit: Mmm no because 1.1.2 renders hard edges as smooth, 1.1.1 and below does as expected.
edit2: maybe the exporter is faulty here, was meant for 1.1.1
edit 3: oh well a cube is a bad example, what about a carglass ;) it's surface is smooth while schematically it's borders are sharp (that's a theorical example, any partially smooth object would fit).
