Indigo v1.0.9 for Linux
Post by OnoSendai » Mon Apr 07, 2008 2:09 am
Consider this build a test.
32 bit build:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
64 bit build:
Let me know if stuff works or not.
Also, I'm interested in performance comparisons with the Windows builds.
SimonLarsen
Post by SimonLarsen » Mon Apr 07, 2008 2:25 am
Great. Thanks!
Anything not included? (:
Post by OnoSendai » Mon Apr 07, 2008 2:26 am
No, I think everything should work
zsouthboy
Post by zsouthboy » Mon Apr 07, 2008 2:53 am
You are a god among...people that are not gods.
Thanks Ono!
Post by OnoSendai » Mon Apr 07, 2008 3:39 am
Added 32 bit build.
Post by pixie » Mon Apr 07, 2008 4:31 am
how the two builds compare, anyone had tested them?
manitwo
Post by manitwo » Mon Apr 07, 2008 5:56 am
unfortunatly not working for me - indigo don't accept values below 1.
eg. it keeps sayin:
 IndigoDriverExcep: SceneLoaderExcep: aperture_radius must be greater than zero (e.g. 0.001)
till i set this value above 1.
and when i set all values within the camera settings in the igi above "1", indigo closes before starting to render.
anyway ... THANKS ono for making a linux version. :wink:
[edit] ... oh, i'm using the 32bit one.
Macrob
Post by Macrob » Mon Apr 07, 2008 6:48 am
manitwo, you are my hero :)
Ono see: I´m not doomed :lol:
Does the 64bit version work now, manitwo?
manitwo
Post by manitwo » Mon Apr 07, 2008 6:51 am
no problem macrob ;)
.... tho no 64bit OS here for testing
Macrob
Post by Macrob » Mon Apr 07, 2008 6:52 am
I had the same promlem with the 64bit :cry:
Post by OnoSendai » Mon Apr 07, 2008 6:53 am
Ok, thanks guys,
I have a suspicion of what the problem may be.
manitwo
Post by manitwo » Mon Apr 07, 2008 6:57 am
just in case you wanna know, indigo crashes right after:
Loading Scene '/path_to_my_scene/scene.igs'...
dougal2
Post by dougal2 » Mon Apr 07, 2008 7:53 am
I just ran the 64bit version on Ubuntu64 hardy (unstable). Loaded+rendered the diffuse_transmitter_test scene perfectly.
It is just a tiny bit slower than the windows version.
linux: 255,000 s/s
windows: 260,000 s/s
EDIT: There's a slight problem with the GUI though, the log window has no scroll bar and not much history (can scroll back a little way with the mousewheel), and the render image fills the entire window, with the log window on top:
zsouthboy
Post by zsouthboy » Mon Apr 07, 2008 8:05 am
I haven't had a chance to test this version, but the .8 era Indigo was 10 - 30% faster in linux than windows, so your results are suprising.
As soon as I get a chance I'll try it out.
manitwo
Post by manitwo » Mon Apr 07, 2008 8:12 am
strange - rendering something with "indigo" don't work whereas rendering with "indigo_console" works great :? :D
i'm on ubuntu hardy 32bit btw..
