Indigo Renderer 4.4.10 Beta
15 posts • Page 1 of 1
Post by OnoSendai » Thu Jul 16, 2020 3:08 am
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_4.4.10_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_v4.4.10.tar.gz
IndigoRenderer4.4.10.dmg
Indigo RT for Windows 64-bit:
IndigoRT_4.4.10_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_v4.4.10.tar.gz
IndigoRT4.4.10.dmg
Changelog:
4.4.10
* Fixed performance scaling when rendering with multiple Nvidia GPU devices.
* Added initial support for baking lightmaps.
See light_map_baking_ob_uid, generate_lightmap_uvs, capture_direct_sun_illum render settings.
* Updated Open Image Denoise to 1.2.2 - slightly faster and improves denoising somewhat.
* Fixed some clashes between Open Image Denoise and the Intel OpenCL driver.
* Printing line and column numbers for more IGS parsing errors.
* Enabled CPU bucket rendering for the benchmark.
* Fixed some missing UID translation for included files for IES, emission scales, diffuse transmitter and fast SSS materials.
* Igmesh files can now be drag-and-dropped into Indigo for previewing.
* Made bump maps on blend materials under coatings or in double-sided thin materials work.
* Added a combo-box to select the material preview scene, can now render all the preview scenes that the dedicated mat preview can do, in the main render view.
* Bumped included SkIndigo version to 4.4.10.1.
pavoda
Re: Indigo Renderer 4.4.10 Beta
Post by pavoda » Thu Jul 16, 2020 11:09 am
nice!
wob
Post by wob » Thu Jul 16, 2020 5:58 pm
blend materials does not render yet (the same error as for 4.4.9, latest working version with blends - 4.4.8). try to rendered simple cube with gold material with cinema 4d exporter ( https://www.indigorenderer.com/materials/materials/810 ) :
can you fix it? it's seems as critical error.
rendering doesn stop when spp limit is reached in network mode (network node is still working, but rendering on master is finished) - latest working version with "normal stop" is 4.4.6 (this error appears in 4.4.6 with new "pausing mode"):
just make a setting to turn on or off "pausing for finished render". it's not an interesting feature for all animation scenes. only for static one-frame renders.
p.s.
my congratulations! GPU utilization graph seems incredibly beautiful. 2 NVIDIA GPUs - very close to 100% utilisation, all time. it's 10-20% of additional rendering speed. i think now indigo without hardware raytracing is faster then octane with hardware raytracing ;) does indigo support 3 or more gpus now?
"Added initial support for baking lightmaps"
when will you update the cinema 4d exporter? it's too many new features of standalone without exporter from cinema: i mean scatter, fabric, baking lightmaps (and very old problem with section plane)
...and please make setting for png depth in standalone
Post by pixie » Thu Jul 16, 2020 8:18 pm
Post by OnoSendai » Fri Jul 17, 2020 12:48 am
Hi Wob,
Can you please make another test scene that demonstrates this issue, and pack it into a PIGS file, and post here.
I can't replicate the problem.
wob
Post by wob » Fri Jul 17, 2020 5:47 am
Hi Wob,
here is pigm. test it in gpu mode (you'll get error, cpu mode works fine):
GOLD.zip
(77.32 KiB) Downloaded 32 times
wob
Post by wob » Fri Jul 17, 2020 5:50 am
https://www.indigorenderer.com/materials/materials/1133
It just crashes
yes, this material does not render too in gpu mode (but works in cpu mode):
Error while processing material 'BlendMaterial' (UID 9):
Failed to find param info for blend(phong,blend(phong,diffuse))_nonbasic_345368794681950392_a::albedo
Indigo version: Indigo Renderer v4.4.10, Windows 64-bit build.
easyarchitect
Post by easyarchitect » Fri Jul 17, 2020 6:52 pm
Ono could you explain this function better? I can't find any references or details.
Thank you very much
AD
Originalplan®
Post by Originalplan® » Sat Jul 18, 2020 7:46 am
Hi Wob,
GOLD.zip
I see no difference on Mac in GPU and CPU mode. Also renders fine from c4d to Indigo.
No error code whatsoever. Maybe it's a win only problem or specific to Nvidia.
Originalplan®
Post by Originalplan® » Sat Jul 18, 2020 7:51 am
It just crashes
Same, works fine no crashes on macOS.
wob
Post by wob » Sat Jul 18, 2020 4:17 pm
It just crashes
you're lucky ;)
Post by OnoSendai » Thu Jul 23, 2020 12:03 am
Here's some documentation about lightmap baking: https://www.indigorenderer.com/document ... map-baking
wob
Post by wob » Thu Jul 23, 2020 9:55 pm
Hi Wob,
this problem desappeared when i change memory bar on my pc, i think it was just a hardware ddr4 error with strange crashes of another apps on my pc too.
p.s. opencl improvements of 4.4.10 add 15%-20% of render speed on nvidia multi gpu, i just test it on complex test scene (4.4.5 - 3:36, 4.4.10 - 3:02). nice update!
Zalevskiy
Post by Zalevskiy » Sun Aug 02, 2020 4:35 am
No such function, function argument, named constant or let definition 'll1l11ll11lll1l111111l1l1111ll1l1'.
Windows 10 Nvidia 950M GPU Mode
wob
Post by wob » Tue Aug 04, 2020 2:00 am
now indigo's main lag is a unavailability of traditional "solid" fog environment. recently i tested indigo's sss volumetric box (gpu mode) on interior animation project (animated camera, static interior) in 5000spp (not the smallest count of spp for animation) and i can't get fully clear video, using very powerful temporal denoising by davinci resolve and topaz denoise / gigapixel denoisers, because the fog was a quite grainy (5000spp is completely enough for non-fog video project). and indigo's denoiser just does not work with sss fog (makes glow solid spot instead fog). i know, it possible to use 10000 or more spp to get better results, but it negates indigo's advantage in rendering speed by comparison with redshift or vray, which have solid (non-pixelized, like indigo) fog enviromnents (like a indigo's sky model - it's drawn as solid, not "spp pixelized" object).
interiors with fog looks much better than without fog. pixelized fog is not a problem for static images (by old-school interior designers), but if you will try to make animated video with sss fog - you'll get terrible results, even with powerful denoisers. i wish to test indigo's sss fog in 4k resolution to make noise smaller because of 4k has a smaller pixels than 720p or 1080p. but it will be better to make solid fog evironment like indigo draws its solid sky object.
p.s. scatter objest also is very important to realization (cinema 4d / blender).
p.p.s. later: 4k 5000 spp with topaz denoise ai 2.2.4 (classic non clear ai denoiser mode) looks fine.
