Indigo Renderer 4.4.9 Beta
Originalplan®
Re: Indigo Renderer 4.4.9 Beta
Post by Originalplan® » Tue Jun 30, 2020 10:25 am
@mpro
Thanks! Interesting problem.
It seems the issue is only present when denoise is active. Otherwise works fine on all CPU & GPU modes.
Let's see what the devs say about it.
Post by OnoSendai » Tue Jun 30, 2020 4:00 pm
mpro31 wrote:
Sun Jun 28, 2020 5:56 am
Hello Indigo team,
This issue has raised before. Noise reduction does not work most of the time. It's not a scene issue. It's not an Intel issue as it does not happen to other renderers who use the same algorithm, it has something to do with implementation.
I would appreciate taking a look.
Best,
K.
Preliminary investigation indicates that this issue is due to having very small values in the render buffer.
For example, from pick info: HDR sRGB pixel colour r=1.7974841e-12, g=1.3779304e-12, b=1.3725927e-12, a=1
The issue goes away if you make the emitters much brighter (and can then turn down the tonemapping scale).
I'll look into it some more though.
mpro31
Post by mpro31 » Wed Jul 01, 2020 5:24 am
@OnoSendai
Hello,
Indeed this solution works, I have to further try that in different scenes but it seems like small values in lighting cause the problem.
Thank you very much!
