Indigo Renderer 4.2.24 Stable Release Candidate
8 posts • Page 1 of 1
Post by OnoSendai » Tue Jun 11, 2019 11:26 pm
This is a stable release candidate.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.2.24_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.2.24.tar.gz
IndigoRenderer4.2.24.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.2.24_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.2.24.tar.gz
IndigoRT4.2.24.dmg
Changelog:
4.2.24
* GPU: Fixed crash with realtime changes in some cases.
* GPU: Fixed problem when selecting region during subres rendering.
* GPU: Fixed error when coating was the child of another material.
* GPU: Fixed error where unused lights on a higher layer caused garbled image display.
* Fixed crash when rendering an IGQ where the render output dir does not exist.
* Added Render Channels tab to options dialog, added 'normalise depth channel' setting.
* Background depth will be zero/black when normalise depth channel is disabled.
* Fixed vignetting being applied to non-beauty render channels.
* Fixed MLT and non-beauty render channels not working together properly.
* Updated bundled SkIndigo to SkIndigo-4.2.21.3.
Re: Indigo Renderer 4.2.24 Stable Release Candidate
Post by zeitmeister » Wed Jun 12, 2019 8:34 pm
Yeah!! Thanks Ono!
Post by StompinTom » Wed Jun 12, 2019 11:34 pm
Awesome!
pavoda
Post by pavoda » Thu Jun 13, 2019 5:07 am
nice!
yonosoy
Post by yonosoy » Thu Jun 20, 2019 7:59 am
Very cool.
Physical aperture diffraction don´t work well. Just change to bidirectional path tracing and all is black.
Aperture diffraction.pigs
(2.18 KiB) Downloaded 9 times
Post by Zom-B » Thu Jun 20, 2019 8:20 pm
iirc the original sky model had issues once the sun is set to low...
changing to "captured simulation" does fix that...
yonosoy
Post by yonosoy » Thu Jun 20, 2019 8:42 pm
Hello Zom-B.
The extra atmospheric sun is selected in the file. This has never been a problem. I can not obtain aperture diffraction with atmosphere simulation. This must be a mistake, I think ...
In fact, I usually simulate the atmosphere by moving the camera around the Earth, so the sun can have any value, there is no "low" consideration in this (80-100 degrees usually, the sun spinning over the equator).
Thanks for the information, the problem is limited to the extra atmospheric sun.
Edit with a test, same file.
V 4.2.24 (200 samples/p)
V 3.8.23 (245 samples/p)
Zalevskiy
Post by Zalevskiy » Fri Jun 28, 2019 11:17 am
https://www.dropbox.com/s/eh56ti0319ce6 ... 3.mp4?dl=0
An error was found when working with materials:
1. Open the material file
2. Manually rename medium
3. Choose a rendering mode
Result = RGB dispersion does not work?!
Milk_02.pigm
(579 Bytes) Downloaded 4 times
