Indigo Renderer 4.0.41 Beta Release
Posted: Wed Jul 27, 2016 6:30 am
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.0.41_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.0.41.tar.gz
IndigoRenderer4.0.41.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.0.41_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.0.41.tar.gz
IndigoRT4.0.41.dmg
Changelog:
IndigoRT4.0.41.dmg
Changelog:
4.0.41
* GPU PT: Fixed problem with Phong nkdata materials as children of non-basic materials.
* GPU PT: Fixed some bugs that sometimes caused crashes in realtime changes with GPU enabled.
* GPU PT: Changing e.g. the substrate material of a coating will correctly trigger a GPU rebuild.
* Made it so that texture exponent -> texture roughness conversion is only effectively applied if roughness param is actually edited in UI.
* Improved texture exponent -> texture roughness conversion.
* Made some scene nodes (render settings and tonemapping currently) be serialised and saved in IGI files.
This allows tonemapping settings, whitepoint, curves etc.. to be saved and loaded with the IGI.
* Bumped IGI format version to 8.
* Made colour curves work with loaded images.
* Made light layer setting updates work for loaded images.
* Added some tooltips for material control.
* Changed label from 'Emission' to 'Emission Mult'.
* Increased blend param step, also made max value 1.0.
