Indigo Renderer 3.8.4 Beta Release
dakiru
Re: Indigo Renderer 3.8.4 Beta Release
Post by dakiru » Thu Jun 19, 2014 10:57 am
Hi guys,
I wasn't successful to render anything with CUDA under ArchLinux:
dak@380v ~ % uname -a
Linux 380v 3.15.1-1-ARCH #1 SMP PREEMPT Tue Jun 17 09:32:20 CEST 2014 x86_64 GNU/Linux
With OpenCL everything seems to work as intended:
With CUDA rendering seems to start, but then halts and the only way to exit Indigo is to terminate the process:
Here is the report from hwinfo:
dak@380v ~ % hwinfo --gfx
26: PCI 100.0: 0300 VGA compatible controller (VGA)
  [Created at pci.328]
  Unique ID: VCu0.GiL15M97RN6
  Parent ID: vSkL.V9w+57PSXi8
  SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
  SysFS BusID: 0000:01:00.0
  Hardware Class: graphics card
  Model: "nVidia GF100 [GeForce GTX 470]"
  Vendor: pci 0x10de "nVidia Corporation"
  Device: pci 0x06cd "GF100 [GeForce GTX 470]"
  SubVendor: pci 0x1043 "ASUSTeK Computer Inc."
  SubDevice: pci 0x8347
  Revision: 0xa3
  Driver: "nvidia"
  Driver Modules: "nvidia"
  Memory Range: 0xfc000000-0xfdffffff (rw,non-prefetchable)
  Memory Range: 0xd8000000-0xdfffffff (ro,non-prefetchable)
  Memory Range: 0xd4000000-0xd7ffffff (ro,non-prefetchable)
  I/O Ports: 0xac00-0xac7f (rw)
  Memory Range: 0xfe700000-0xfe77ffff (ro,non-prefetchable,disabled)
  IRQ: 49 (32396 events)
  I/O Ports: 0x3c0-0x3df (rw)
  Module Alias: "pci:v000010DEd000006CDsv00001043sd00008347bc03sc00i00"
  Driver Info #0:
    Driver Status: nouveau is not active
    Driver Activation Cmd: "modprobe nouveau"
  Driver Info #1:
    Driver Status: nvidia is active
    Driver Activation Cmd: "modprobe nvidia"
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #8 (PCI bridge)
Primary display adapter: #26
dakiru
Post by dakiru » Thu Jun 19, 2014 11:06 am
There is a tiny UI bug - supersampling factor title doesn't react on a font change in qtconfig-qt4:
Post by zeitmeister » Sat Jun 28, 2014 7:19 am
Voroni ISL shaders don't work.
For example this material:
http://www.indigorenderer.com/forum/vie ... 57#p102057
I always get an error message...
dakiru
Post by dakiru » Sat Jun 28, 2014 7:40 am
Yep, I can confirm that too.
Error while building scene: Error while loading diffuse material 'letchee': Failed to find function 'voronoi(vec2, vec2)'.
buffer, line 93:
	pyra(voronoi(tile(mypos()), mypos()), mypos())
Post by Oscar J » Mon Jun 30, 2014 11:26 pm
Exit portals now make the scene clear up more slowly than when not using them... First one is without EP.
Post by Oscar J » Mon Jun 30, 2014 11:31 pm
The same thing happens in 3.6 actually, maybe it's a blending issue.
Online
Post by OnoSendai » Tue Jul 01, 2014 12:38 am
aleksandera wrote:I'm still getting dark edges when rendering with large aperture.
However I can still use the post-processed dof so the problem is not that big.
This problem should be fixed in the next release (3.8.5).
aleksandera
Post by aleksandera » Tue Jul 01, 2014 11:20 am
So cool :) I have done a simple test today. It doesn't look that bad already. However I have to measure the focal distance next time I'm taking the background images. Also maybe glue an obstacle map directly on the lens,
hm, that would be interesting...
Post by Oscar J » Wed Jul 02, 2014 1:38 am
Don't... effin'... tell me that scene is all modelled...!?
aleksandera
Post by aleksandera » Wed Jul 02, 2014 2:17 am
Oscar J wrote:Don't... effin'... tell me that scene is all modelled...!?
No no no, just the balls are. It's just an compositing attempt. ;)
aleksandera
Post by aleksandera » Wed Jul 02, 2014 3:20 am
BTW, I have to admit while working with compositing I don't understand why is the opacity slider there?
It has no purpose for me if every time I move it one of the images fades out. It would be logical to see both of the images all the time, so one cud than adjust the camera settings to match the composition (?)
Sorry for my BE :)
Post by Oscar J » Wed Jul 02, 2014 7:10 am
Phew... was about to give up and uninstall, hehe.
Nice work nonetheless.
aleksandera
Post by aleksandera » Thu Jul 03, 2014 2:17 am
Thank you Oscar J :)
Users browsing this forum: No registered users and 154 guests
