Page 1 of 2
Indigo Renderer 3.6.11 Beta Release
Posted: Wed Apr 17, 2013 3:26 am
by OnoSendai
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.6.11_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.11_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.11.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.11.tar.gz
IndigoRenderer3.6.11.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.11_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.11_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.11.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.11.tar.gz
IndigoRT3.6.11.dmg
Changelog:
3.6.11
* Thin glass etc.. now has zero alpha for transmitted light.
* Loading alpha channels of EXRs.
* Fixed garbling when saving to EXR.
* Fixed display of loaded images with alpha channels.
* Made GetAdaptersInfo loop a few times until it succeeds.
* Fixed some numerical issues with ray-sphere intersection.
Re: Indigo Renderer 3.6.11 Beta Release
Posted: Wed Apr 17, 2013 3:44 am
by Stinkie
Thanks.
Posted: Wed Apr 17, 2013 4:10 am
by CTZn
Thank you !
Posted: Wed Apr 17, 2013 4:12 am
by wlf_alex
Thanks a lot, Ono !!!
Posted: Tue Apr 30, 2013 12:48 am
by Pibuz
Sorry guys: how is the "new" alpha background rendering feature supposed to work? I have some issue trying to use that..
Posted: Tue Apr 30, 2013 1:11 am
by Zom-B
Pibuz wrote:Sorry guys: how is the "new" alpha background rendering feature supposed to work? I have some issue trying to use that..
Its a checkbox in the Render Settings and instead of rendering Indigo Sky or background HDRI you get transparency at that area.
Also transparency behind glass like glass windows becomes transparent but keeps the reflections. see this car windows as an example:
http://www.indigorenderer.com/node/1868
Posted: Tue Apr 30, 2013 1:39 am
by Pibuz
Don't want to sound jerky, but don't you think it could be too slow in complex scenes?
I mean, black/white was complete in 10 minutes max.. And it worked fine most of the times when you could sacrifice reflections..
Posted: Tue Apr 30, 2013 3:15 am
by Oscar J
Hi Pibuz,
IMO this is one of the greatest new features we've been spoilt with for a long time. It allows me, as an automotive renderer, to render the car with a HDRI and an asphalt ground (which I set to "invisible to camera") without actually seeing anything else than the car in the render, apart from in the reflections. And, best of all, it's done all at once - the object and its materials gets rendered at the same time as the alpha
This, together with the shadow catcher feature, allows for easy integration with a backplate.
For example, you could render an entire room with an ugly HDRI - with the alpha box checked, and then just pick an environment to place outside - using only one render (and no magic tool struggling or ugly white lines at the edges).
Posted: Tue Apr 30, 2013 3:18 am
by Zom-B
Pibuz, now you don't need to render an extra pass but have full Alpha support also for DOF and Motion Blur and (semi)transparent Materials. This stuff wasn't manageable with previous BW render...
The rendering doesn't take extra time but renders the alpha on the run.
Its a win-win situation :)
Posted: Tue Apr 30, 2013 5:15 am
by Pibuz
..oh...I see... Used to the former method, I launched the last rendering without it....
Thanks for the explaination Zom-B! As always :)
Posted: Tue Apr 30, 2013 4:19 pm
by chiataimakro
scene with 3 glass cups. everything looks fine, but after i switch the device to i7 3610QM(OpenCL):
very cool artifact. i think it's a problem of floatingpoint precision..
Posted: Wed May 01, 2013 5:44 pm
by delle
Zom-B wrote:Pibuz wrote:Sorry guys: how is the "new" alpha background rendering feature supposed to work? I have some issue trying to use that..
Cool!
Posted: Wed May 01, 2013 8:01 pm
by CTZn
chiataimakro wrote:scene with 3 glass cups. everything looks fine, but after i switch the device to i7 3610QM(OpenCL):
Is the scene scaled correctly ?
If this can be reproduced but not fixed I'm betting that Glare Tech would use the PIGS. Pack the scene using the Indigo packing tools and send it please to
support@indigorenderer.com.
Posted: Sun May 05, 2013 3:17 am
by lape
Is the shadow pass render mode working with Indigo RT? Just installed 3.6.11 but can't find the checkbox for this mode....
Posted: Mon May 06, 2013 11:26 pm
by fused
lape wrote:Is the shadow pass render mode working with Indigo RT? Just installed 3.6.11 but can't find the checkbox for this mode....
Hi lape,
it might not be supported by Indigio RT at the moment.
We are currently still evaluating which of the new features will be available in the 3.6 stable version of Indigo RT.
