The most probable issue Pibuz is a light leak. Check wall angles, put a black box around save for the EPs...
edit: I'm not sure if this can even be related afterthought.
Indigo Renderer 3.6.9 Beta Release
Re: Indigo Renderer 3.6.9 Beta Release
I remember to encounter something like that before.Pibuz wrote:In the same scene conditions, when not using exit portals I had to put the emission power of the EXR to absurd values; when I introduced the exit portals in the latest tests those values were so high that burned the image to the point it seemed like..inverted.
The problem is that your Sky had some EmissionScaling on... based on Emitter Size!!!
That Size depended Emission Scaling kicks hard in the nuts once you use a Exit Portal, where the Emitter scale drops down to your ExitPortal meshes... boom.
Solved with the latest version you sent me. What's curious is that I tested on 3 slaves and:OnoSendai wrote:
I think i have a fix for this problem. I have also made the server try and rebind for 60 s if it fails initially.
* OS X with updated version works every time
* OS X with older version does not work at all (connects then disconnects)
* Linux version (old) works every time after I updated only the master OS X machine
Users browsing this forum: No registered users and 102 guests
