Indigo Renderer 3.6.9 Beta Release
Re: Indigo Renderer 3.6.9 Beta Release
Post by pixie » Sat Mar 09, 2013 9:16 am
delle wrote:
Added invisible to camera option to models.
Could you please suggest the igs-code to enable this option?
Thank you very much.
A.Delle
In the scene pick the desired object, set to invisible, save the scene and presto! ;)
M-Pixel
Post by M-Pixel » Sat Mar 09, 2013 10:14 am
THX .. very nice
Post by StompinTom » Sat Mar 09, 2013 10:18 am
This is awesome!
One thing: when using Edit > Copy Image and pasting into Photoshop, the alpha transparency is not preserved (noisy black and white background where it should be transparent). Saving to a PNG works fine.
Antonis777
Post by Antonis777 » Sun Mar 10, 2013 1:00 am
Some problems in the new release. Image takes far too long time to update if I tweak with light layers or material settings or anything else. Sometimes it crashes. No specific problems with previous releases.Also I downloaded CTZn's material http://www.indigorenderer.com/materials/materials/961 and got this result (don't know for sure though if it's abug of the new release).
Post by CTZn » Tue Mar 12, 2013 2:22 am
A.Delle
The tag is not written by Indigo yet, it can not be implemented without a fix or more intel.
@Antonis: I don't think that the shader should break the mesh like this. Perhaps it's my code clamping the coordinates but I found similar shading limitations in different circumstances.
Post by pixie » Tue Mar 12, 2013 11:59 am
CTZn wrote:The tag is not written by Indigo yet, it can not be implemented without a fix or more intel.
OMG sloppy programming, it can't be! xD
Post by CTZn » Wed Mar 13, 2013 2:50 am
From me it's iterative empirism, from Glare it's a beta feature :)
Post by CTZn » Wed Mar 13, 2013 4:29 am
SPOILER:
and here's the kitty:
<invisible_to_camera>true</invisible_to_camera>
on the model
Post by CTZn » Wed Mar 13, 2013 7:14 am
CTZn wrote:SPOILER:
on the model
Scene parsing error: Found unexpected element 'invisible_to_camera'.  (In element 'model', around line 103, column 1)
As it seems there is no XML support (at all ?) at this point.
Post by OnoSendai » Wed Mar 13, 2013 9:44 am
CTZn wrote: As it seems there is no XML support (at all ?) at this point.
I think you will have to use the <model2> tag.
Post by CTZn » Wed Mar 13, 2013 2:09 pm
ouch that's heavy stuff. I think someone was writing a doc on this guy ?
Amazing new features otherwise.
Arkon
Post by Arkon » Fri Mar 15, 2013 3:25 pm
Hi! in this release not working "assign materials". Not so good)
Post by Pibuz » Sat Mar 23, 2013 4:27 am
Cool release! Just tested the DOF pass and it works great! Here's an idea: when enabling the "depth pass" rendermode would it be possible to "hide" all existing light layers and to rename (or substitute) the first one with the name of "depth pass" or something similar (being this operation reversible when one goes back to a traditional render mode)? at the moment all layers are kept and it's not immediate to understand that the render pass is only in the first one, maybe called in some other way ("sun" in my case :) ).
Tested the "invisible to camera" too: cool and handy. Is there a way I can hide lights from reflections too? :D
Post by StompinTom » Sat Mar 23, 2013 1:23 pm
Pibuz wrote:Cool release! Just tested the DOF pass and it works great!
Er... DOF and Z-depth are two completely different things. Just to be clear, I'm assuming you mean the Z-depth pass?
Post by Pibuz » Sat Mar 23, 2013 8:37 pm
ER ops: yes I meant that :D
I made a mess since I use that in photoshop to change the dof focus :D
