Indigo Renderer 3.4.9
Post by fused » Fri Oct 12, 2012 4:19 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.4.9_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.4.9_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.4.9.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.4.9.tar.gz
IndigoRenderer3.4.9.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.4.9_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.4.9_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.4.9.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.4.9.tar.gz
IndigoRT3.4.9.dmg
Changelog:
3.4.9
* Fixed light layers not working properly in console.
* Fixed a problem where to UI would go into a state where you can't close or open when a non-existent scene file was opened.
* Fixed reflection shading normal effect for glossy transparent.
* Added cull_geometry option to section planes (and made it available in the UI).
An example of culling on versus culling off on section planes:
Culling on. The geometry behind the section plane is removed. Light from the outside is not blocked (because the geometry was actually removed).
Culling off. The geometry behind the section plane is not removed but ignored for eye rays coming from behind the section plane. Light isn't able to pass through.
Re: Indigo Renderer 3.4.9
Post by StompinTom » Fri Oct 12, 2012 5:06 am
Yeeeeeeeah :D
Post by PureSpider » Fri Oct 12, 2012 5:34 am
OMG YOU GUYSE ARE GENIUSES! I WANT YOUR MAN BABIES!
Post by zeitmeister » Fri Oct 12, 2012 6:00 am
Yeah!
When will the new lef material be implemented? :-))
Post by OnoSendai » Fri Oct 12, 2012 6:29 am
zeitmeister wrote:Yeah!
It already is implemented :)
It will be available after 3.4 stable is done.
Post by pixie » Fri Oct 12, 2012 6:49 am
Hurray!
A few tests
Post by zeitmeister » Fri Oct 12, 2012 7:35 am
OnoSendai wrote:It already is implemented :)
Double-Yeah!!!
delle
Post by delle » Fri Oct 12, 2012 7:41 am
I've been waiting for this since a long time...
Can you suggest the syntax for my exporter?
Thank you!
Post by pixie » Fri Oct 12, 2012 7:45 am
More tests, showing a texture in a hidden wall
Twice the planes twice the fun! :)
Post by OnoSendai » Fri Oct 12, 2012 7:53 am
Thank you!
 <section_plane>
    <point>3 0 0</point>
    <normal>-1 0 0</normal>
    <cull_geometry>false</cull_geometry>
  </section_plane>
delle
Post by delle » Fri Oct 12, 2012 8:09 am
Thank you!
 <section_plane>
  </section_plane>
Thank you,
Do you think that, in the future, this flag will be available for normal meshes ? (e.g. planes)
I've been waiting for this since 4 years ago... see this post!
Post by StompinTom » Fri Oct 12, 2012 9:02 am
Ortho rendering still sometimes gives unexplained transparent materials... Will post a screenshot to demonstrate in a bit!
ENSLAVER
Post by ENSLAVER » Fri Oct 12, 2012 2:11 pm
Awesome, just realized the "sensor width" option in Indigo UI is like the "zoom" when using Ortho :D
On a sidenote, what is the correct way to use Exit Portals with Clipping? If they intersect the walls they light up the cavity which seems like a waste of CPU power.
snorky
Post by snorky » Fri Oct 12, 2012 6:55 pm
yeaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaah
Post by CTZn » Sun Oct 14, 2012 1:09 am
ENSLAVER wrote:On a sidenote, what is the correct way to use Exit Portals with Clipping? If they intersect the walls they light up the cavity which seems like a waste of CPU power.
You have certainly thought of that since, culling geometry sounds like the best option to take with portals. It will allow the hidden walls to project their shadow onto the portals, as opposed to ressource intensive rays.
Users browsing this forum: No registered users and 138 guests
