Indigo Renderer 4.2.25 Stable Release Candidate
6 posts • Page 1 of 1
Post by OnoSendai » Thu Aug 08, 2019 5:51 pm
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.2.25_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.2.25.tar.gz
IndigoRenderer4.2.25.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.2.25_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.2.25.tar.gz
IndigoRT4.2.25.dmg
Changelog:
4.2.25
* Fixed crash with very large image buffer sizes.
* Showing render channels in drop-down box for loaded IGIs.
Re: Indigo Renderer 4.2.25 Stable Release Candidate
Post by zeitmeister » Sun Aug 11, 2019 8:08 pm
Very cool; thanks for fixing the image buffer issue!
Arkon
Post by Arkon » Thu Aug 15, 2019 12:27 am
Hello )
That's what I still have
Post by fused » Thu Aug 15, 2019 8:14 pm
Hello )
Hi Arkon,
that error means you don't have enough memory to render the image. Try using a lower super sampling factor (with every increases of 1 in super sampling, the memory needed to render the image increases by some factor).
Best,
Yves
rivera-b
Post by rivera-b » Mon Aug 19, 2019 3:09 am
Hello.
Trying to use this version.
Will not process sample scenes.
Using latest skindigo...
Will not process a simple rectangle scene.
Previous versions did well with sample scenes.
MacBook Pro (Retina, Mid 2012)
2,3 GHz Intel Core i7
8 GB 1600 MHz DDR3
Post by Zom-B » Mon Aug 19, 2019 8:04 pm
Hey rivera-b,
try disable your HD Graphics 4000 for GPU rendering!!
Its usually only causing issues due to driver support of OpenCL and in older working Indigo versions it slowed down the render for sure, go back and test it.
