Log in or Register
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3, 4  Next
Offline
http://www.indigorenderer.com/joomla/in ... &Itemid=62
Changelog:
1.0.8
* Improved energy conservation for Phong material
* Increased max albedo for phong and diffuse from 0.9 to 1.0
* added Oren Nayar material
* staticly linking with OpenEXR
* OpenEXR support enabled for windows 64-bit build
* added specular_reflectivity_spectrum option for the Phong material.
The specular reflectivity spectrum for Phong materials defines the specular reflectivity at normal incidence.
If this element is present, then diffuse will be set to zero.
The specular reflectivity spectrum can be used to create metal materials without using n-k data.
Use the specular reflectivity spectrum like this:
Code:
<material>
      <name>spheremat</name>
      <phong>
         <diffuse>0.0 0.0 0.0</diffuse>
         <exponent>300</exponent>
         <specular_reflectivity_spectrum>
            <rgb>
               <rgb>0.6 0.6 0.6</rgb>
               <gamma>1</gamma>
            </rgb>
         </specular_reflectivity_spectrum>
      </phong>
   </material>
The Oren-Nayar BRDF models very rough surfaces, such as clay, the moon, sprayed concrete etc... It differs from a Lambertian BRDF in that it has more back-scattering.
The sigma parameter is a roughness parameter that controls the amount of back-scattering.
Oren nayar material:
Code:
<material>
      <name>3</name>
      <oren_nayar>
         <albedo_spectrum>
            <uniform>
               <value>0.7</value>
            </uniform>
         </albedo_spectrum>
         <sigma>0.2</sigma>
      </oren_nayar>
   </material>
File comment: Oren Nayar test.
Sigma increases to the right.
Leftmost sphere is Lambertian. (diffuse)
File comment: Low exponent Phong with better energy conservation than before.
File comment: metal using
File comment: Blue metal using specular_reflectivity_spectrum
 Profile
Offline
hmmm ok so 1.0 stable waits a bit longer :wink: more buttons..more wiki :roll:
 Profile
Offline
Haha, yup, little bit longer for 1.0 stable, I decided to improve the Phong model first.
And then I threw in the Oren-Nayar :)
 Profile
Offline
you just cant help yourself can you 8) :D
 Profile
Offline
nope :)
 Profile
Offline
Damn. And you're posting this as I'm taking my break! So many goodies I'm dying to try out here. The new materials look FANTASTIC!
_________________
http://www.bertrand-benoit.com
 Profile
Offline
Heh.. sorry BbB :)
 Profile
Offline
Thx Ono, exr works fine and the new material looks great :D
 Profile
Offline
Wow, I hadn't thought see 1.0.8 so soon :)
Thanks a lot for your work Ono!!
Does this mean that we can expect regularly also testversions in 64bit?!
_________________
C4D User - My Portfolio
iMac 2x2.8Ghz on Vista64 & AMD 4x3.0Ghz
 Profile
Offline
WOW tnx ONO
Luca. ;)
 Profile
Offline
Great!!!!!!!!!! tnx ONO
 Profile
Offline
in oren nayar where is the colour from? says uniform... :roll:
 Profile
Offline
wow ono! that looks sweet! especially the blue sphere! i love it x3
greetz Seb
_________________
http://sebsemper.deviantart.com/
 Profile
Offline
thanks a lot, Ono!! very interesting news!
ciao!
 Profile
Offline
Thanks Ono... astonishing as always.
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
