Download Trial Buy now
Search  | Login  | Register
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
Offline
Site Admin
Sweet, now it just needs some vegetation and snow shaders :)
 Profile
Offline
hehe, theres a blend shader for that!
circular gradient + fbm again :)
the snow is actually a little more displaced than the rocks :P
8)
 Profile
Offline
oh and of course the shader generated by cindigo:
Code:
    <material>
        <name>rock_mid0_b_l_e_n_d_A</name>
        <oren_nayar>
            <sigma>
                <constant>0.200000</constant>
            </sigma>
            <albedo>
                <texture>
                </texture>
            </albedo>
            <texture>
                <uv_set>default</uv_set>
                <path>..\..\..\..\..\Desktop\rock_03.jpg</path>
                <exponent>2.200000</exponent>
                <a>0.000000</a>
                <b>1.000000</b>
                <c>0.000000</c>
            </texture>
            <displacement>
                <shader>
                    <shader>
                        <![CDATA[def Vec3ToReal(vec3 v) real : ((doti(v) + dotj(v) + dotk(v)) / 3.0)
                  def noise01(vec3 v) real : ((noise(v) + 1.0) * 0.5)
                  def noise01(vec2 v) real : ((noise(v) + 1.0) * 0.5)
                  def noise01(real r) real : ((noise(r) + 1.0) * 0.5)
                  def fbm01(vec3 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
                  def fbm01(vec2 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
                  def fbm01(real r, int oc) real : ((fbm(r,oc) + 1.0) * 0.5)
                  def mulCompVec2(vec2 a, vec2 b) vec2 : vec2(doti(a) * doti(b), dotj(a) * dotj(b))
                  def mulCompVec3(vec3 a, vec3 b) vec3 : vec3(doti(a) * doti(b), dotj(a) * dotj(b), dotk(a) * dotk(b))
def eval() real: ((Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 0.35000 * fbm01(mulCompVec2(getTexCoords(0) * 10.0, vec2(1.00000, 1.00000)),8)) * 1.50000 + 1.00000 * noise(mulCompVec2(getTexCoords(0) * 10.0, vec2(0.25000, 0.25000)))) * 6.00000]]>
</shader>
                </shader>
            </displacement>
        </oren_nayar>
    </material>
    <material>
        <name>snow_mid1</name>
        <phong>
            <ior>1.500000</ior>
            <diffuse_albedo>
                <constant>
                    <rgb>
                        <rgb>0.900000 0.900000 0.900000</rgb>
                        <gamma>2.200000</gamma>
                    </rgb>
                </constant>
            </diffuse_albedo>
            <exponent>
                <constant>250.000000</constant>
            </exponent>
            <displacement>
                <shader>
                    <shader>
def eval() real: ((Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 0.35000 * fbm01(mulCompVec2(getTexCoords(0) * 10.0, vec2(1.00000, 1.00000)),8)) * 1.50000 + 1.00000 * noise(mulCompVec2(getTexCoords(0) * 10.0, vec2(0.25000, 0.25000)))) * 6.10000]]>
</shader>
                </shader>
            </displacement>
        </phong>
    </material>
    <material>
        <name>rock_mid0</name>
        <blend>
            <a_name>rock_mid0_b_l_e_n_d_A</a_name>
            <b_name>snow_mid1</b_name>
            <step_blend>false</step_blend>
            <blend>
                <shader>
                    <shader>
def eval() real: (Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 1.00000 * fbm(mulCompVec2(getTexCoords(0) * 10.0, vec2(0.60000, 0.60000)),8)) * 2.00000]]>
</shader>
                </shader>
            </blend>
        </blend>
    </material>
 Profile
Offline
I just got the perlin and fbm shader code indigo uses from nik, so expect the shader previews and c4d internal renderings to be quite accurate :)
 Profile
Offline
trying to add some turbulence to gradient shaders (because c4ds gradient shaders can do that).
doesnt quite look as in c4d but its a start :)
left 50% turbulence, right 25%
oh, and the shader:
Code:
   <material>
      <name>diff_tran</name>
      <diffuse>
         <albedo>
<shader>
                    <shader>
                        <![CDATA[
def fbm01(vec2 v, int oc) real: (fbm(v,oc) + 1.0) * 0.5
def noise01(vec2 v) real: (noise(v) + 1.0) * 0.5
def eval(vec3 pos) vec3: lerp(vec3(0.75,0.0,0.0),vec3(0.0,0.75,0.0),doti(getTexCoords(0)) + (fbm(getTexCoords(0) * 5.0,8) * 0.5))
</shader>
                </shader>
         </albedo>
      </diffuse>
   </material>
 Profile
Offline
Awesome work m8!!!!
_________________
Cindigo user - My Portfolio
AMD 1090T @ 6x3.6Ghz on Vista64
 Profile
Offline
shader previews are fairly accurate, c4d internal and indigo renderer:
File comment: c4d
File comment: indigo
 Profile
Offline
Great stuff fused ! One more year and I'll be there I hope 8)
*cough* that was some dust by the way, I was just lurking for sumthin around and found this !
_________________
it's magic
 Profile
Offline
hello
i start to dive into tech.reference of isl.
But i look in section "Built-in functions – miscellaneous functions", at function posOS()
I have question if dynamic object hit surf, then initiate noise reproduction(like frost or cracks).
Is it possible in isl? Vector of intersection will be return by xpresso or python.
I will to try, it's only concept.
 Profile
Offline
Hello and me again.
Yves you posted new cindigo version with isl-fixes and new sdk.
Can we wrap it(ISL) into such shader structure http://code.vonc.fr/?a=13 or http://code.vonc.fr/c4d/python/examples ... y-Fresnel/ ?
Warp isl symbols in brackets(with inherited options) and unwrap when render-data init().
this experiment don't me let up
(sorry for my English)
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
