SSSdusty air setting how to do it myself?
hello all.
Here is a really great Render from the Finished artwork forum done by enricocerica , and i would like to learn how to set the material myself in the skindigo material editor.
I downloaded the FOG igm in the database, but i find it too dusty,i mean the density is to high and we don t see far enough, this is the reason why i would like to do it myself.
here is the result. I would like to know what values to set where
i hope you can help me!
- this is what i do not know how to set, since at the moment i use the "linked IGM"
- Sans titre-1.jpg (196.74 KiB) Viewed 1838 times
- this is the result with the FOG DLed from the database.
- ssscube exit portal.jpg (269.94 KiB) Viewed 1840 times
- this is the dusty aire reference i would like to reproduce.
- cloitre_indigo_1.jpg (130.22 KiB) Viewed 1837 times
Re: SSSdusty air setting how to do it myself?
http://www.indigorenderer.com/materials ... iew_source
oh i think i start to understand after some hours of toggling.
<scenedata>
<medium>
<name>Material</name>
<precedence>2</precedence>
<basic>
<ior>1</ior>
<rgb>
<rgb>0.1 0.1 0.1</rgb>
<gamma>2.2</gamma>
</rgb>
<subsurface_scattering>
<uniform>
<value>0.0315479</value>
</uniform>
<phase_function>
<uniform/>
</phase_function>
</subsurface_scattering>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>Material</internal_medium_name>
</specular>
</material>
</scenedata>
i found that on the "source" button page. so i made the relation between this.......stuff..... and the interface.
so, should it should be a Specular, with IOR set to 1. What i don t know is which value to lower if i want it less dusty? Precedence? cauchy B? Subsurface scattering? Spectrum?
<scenedata>
<medium>
<basic>
<ior>1</ior>
<rgb>
<gamma>2.2</gamma>
</rgb>
<uniform>
</uniform>
<phase_function>
<uniform/>
</phase_function>
</basic>
</medium>
<material>
<specular>
</specular>
</material>
</scenedata>
- here is the result, i am satisfided, but then what i want to know is if thre is something i should change to make it render faster or easier for the computer? any values ?
- im1256750077.png (233.97 KiB) Viewed 1821 times
- So this is the result i got for the settings, i hope someone of you can tell me if everything is right, or if something is wrong!
- SETTING.jpg (206.59 KiB) Viewed 1819 times
scattering coefficient basically controls the amount of scattering, or 'dustiness'.
YAH it is what i noticed and tryed to understand quite empirically and by reading the user manual. i just wanted to have an idea of the value to input i think i am quite satisfied with what i found.
here is the result with the setting i posted just above. the scene is not interesting but i just wanted to learn and maybe inform future newbies who will want to do it too
- tiddles! and changing tonemapping helps a lot too! really nice!
- ssscube exit portal.jpg (164.69 KiB) Viewed 1759 times
Hi djegoo!
We SketchUp users have a more powerful tool to control the fog: it's called...FOG!
You know that you can set a foggy environment within sketchy if you use the "Fog window" (window->fog): just click the "display fog" check! Set the left cursor to zero and adjust the right cursor to fit your needs.
In SU no need to download materials, no difficult settings Thanks Whaat!
HI PIBUZ!
yeah i tryed it, it works perfectly, but i don t understand why, it is soooo long to render. or maybe i did something wrong. but gonna try again with the fog!
maybe i should have put exit portals and that s why it was so long.
gonna give it a try again.
Your wise advices are always welcome
EDIT : oh, yes, i just forgot to put the exit portal but actually when i set it at the minimum with the Fog window i still find it a chouya too dusty
anyway, i know both methods now ! still good to know
SkIndigo exports the fog color as well. So make sure your fog color is set to white. Otherwise, it may be too 'dusty' for your tastes.
yes, i just noticed that changing the color worked!
shall i consider the fog as a material, i mean set it at 100% white? or ~85 like any other white?
thanks for yer answerrs! gonna try it to compare.
EDIT : seems to be the same, just needed to add more exposure when setted to 85 luminosity.
I think in fact i just forgot the xit portal when testing the fog at the very beginning....
It's not a bad idea to set it to 85% white. Otherwise, you will have no absorption which would result in more light bounces and longer render times.
