Maxigo 1.15.7-Test1a [update-09.07.08]
Feel free to experiment by yourself.lady D wrote:i'm stupid suv... can you post the setting of parameters???pleace
It's the best way to learn what each parameter is doing.
Here's a shot. Pretty much the default settings except iterations is set to 6.
- box_disp.jpg (71.73 KiB) Viewed 5826 times
wow......the displacemente work very well.....but I have a stuid question......what I must do for having the stamp in the render?
filippo
filippo
- stamp
- 11.jpeg (38.78 KiB) Viewed 5806 times
- displacement
- disp ex.jpg (305.99 KiB) Viewed 5808 times
- Doug Armand
Displacement is working great
Had a few simple plays with it- seems to work great. Seems fast too. Will try some more demanding versions later.
At this rate I may stick with 3DS Max - you swine!
Only thing - and I really am nitpicking here. Can you make the map button on the displacement map modifier drag and dropable?
- Display took 0.89192 s
Total render time elapsed: 4 m, 14 s
Done 84680000.00000 samples (275.65104 samples per pixel)
332979.31794 samples / second (3.00319 micro-seconds / sample) - displacement_test.jpg (83.88 KiB) Viewed 5800 times
Doug
Doug Armand
Doug Armand
@filippo
For the information bar set the overlay parameter to true in inifile.xml under Indigo's root directory. I haven't had time yet to put that on the interface.
@doug
Well, i'm using the standard map button. Don't know why it isn't drag and dropable already by default. I also can't find such parameter, so I currently have no idea how to do that.
@doug
- rosario975
- rosario975
- Doug Armand
[quote="suvakas@doug
Well, i'm using the standard map button. Don't know why it isn't drag and dropable already by default. I also can't find such parameter, so I currently have no idea how to do that.[/quote]
Not a biggie - just a simple UI issue.
OK have now tried out a few of the displaced materials in the library - my opinions?
The ImportMat works excellently. No problems. Very easy to use. It's neat that you take the .pigm file and unpack the textures under the Indigo program folder. Once I worked that out was real easy to add the displacement map to the modifier. Nice implementation.
Probably a known issue - but doesn't seem displacement works with emitters?
Looking real good. I have to say the ease of using Indigo materials with your implementation in 3DS Max is making me re-evaluate my move to blender. Nice work
Anything else on this version you want testing Suvakas?
- TestMaxigo.max-frame-0000 - Copy.jpg (238.8 KiB) Viewed 5738 times
Doug
Doug Armand
Doug Armand
