Download Trial Buy now
Search  | Login  | Register
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
Offline
Hi all,
I have a concern about an object that I modeled in zbrush and then export to C4D (r12) with maps of displacement and normal maps. I tried to convert the material and then to launch a report on indigo, but it does not work. No detail is not apparent. How can I fix it and what type of setting should I do? thank you in advance for your help.
I will put you in copying the model of screen captures in zbrush, and rendered via cinema4d (AR3)
_________________
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
 Profile
Offline
here's what I get when I run a report on the setting here indigo.t matter in C4D.
Thank you for your help.
_________________
Zbrush 4
 Profile
Offline
Hey Schmums,
first of all check your export scene scale to be correct, you'll find it under the environment tab in the Indigo renderer settings.
If you export your Dragon as 200m big, a 2.5cm displacement will not be visible ;)
Next you need to subdiv your basemesh! Do so by using C4Ds Hypernurbs or Indigos subdiv modifier by right-clicking on the mesh in the object tree > Cindigo Tags > Indigo subdivision Tag.
Using Indigo subdiv modifier disable phong angle breaks (unchecking on top box of C4Ds Phong Tag)
I hope that helps :)
_________________
Cindigo user - My Portfolio
AMD 1090T @ 6x3.6Ghz on Vista64
 Profile
Offline
Thank you s much!
It's very clear i'm try it
_________________
Zbrush 4
 Profile
Offline
Hello, I followed the steps that you indicated to me. However I have a recurring error message that prevents me enough to run a report (see the error message). And impossible to see where it comes from I'm looking in the settings of indigo c4d. I can not find or it's coming
_________________
Zbrush 4
 Profile
Offline
Hi SCHMUMS,
which version of Cindigo and which version of Indigo are you using? They need to match (for Cindigo 3.2.1, for example, you should at least use Indigo 3.2.1 or newer, not older).
Regards,
Yves
 Profile
Offline
If you encounter errors or bugs, first thing to do always, is to use the latest version of exporter & Indigo:
Indigo 3.2.9: viewtopic.php?f=1&t=11481
Cindigo 3.2.9.1: viewtopic.php?f=10&t=11491
Regarding your scene setup:
- the dragon needs a C4D phong Tag as described in my previous post!
- the subdiv tag needs to ckeck smoothing, to smoth the mesh like a C4D Hypernurb would do
- play with viewdependet settings for some saving in triangle count and RAM usage in Indigo
(Not suported if your mesh is in quads, then it gets ignored!)
_________________
 Profile
Offline
Ah yes ... actually last night I downloaded version 3.2.9.1 of cindigo (osx) and did not do the update INDIGO which remained in 3.0.10 ...
Zom-B sorry I had understood the need to disable the phong tag ...
Sorry for bad English (I'm french guy)
_________________
Zbrush 4
 Profile
Offline
disabling the checkbox only, so no angle limitation happens.
No problem mate ;)
_________________
 Profile
Offline
I think I did as you had indicated to me previously. I metsz all my settings as the result it gives me something very inflated ...
_________________
Zbrush 4
 Profile
Offline
for the phong tag disable the "Angle maximum" checkbox, that I was referring to previously. because by that on angles higher then 80° Indigos displacement disconnects polygons and causes black holes in your mesh!
Your displacement map is center based with RGB 128 grey collor a zero point. to use such displacement & bump maps you need to lower the c value to half of b value.
In your settings it would be:
a: 0
b: 0.6
c: -0.3
_________________
 Profile
Offline
AC seems to work!
Thank you for your help and patience
_________________
Zbrush 4
 Profile
Offline
SCHMUMS wrote:
AC seems to work!
Be so nice and reward my effort with a rendering :)
_________________
 Profile
Offline
And last question, is that I can combine (as in c4d) of my displacement map and normal map? If so in what channel is what I have to put
_________________
Zbrush 4
 Profile
Offline
There no support for normal maps in Indigo, the question was asked 3 days ago: viewtopic.php?p=114014#p114014
You will probably find a related topic into the Bugs and Requests subforum if you want to add your voice in.
_________________
it's magic
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
