Download Trial Buy now
Search  | Login  | Register
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
Offline
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.2.5_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.2.5_Setup.exe
IndigoRenderer3.2.5.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.2.5_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.2.5_Setup.exe
IndigoRT3.2.5.dmg
Changelog:
Quote:
3.2.5
* Alpha tracer now traces through partial null blends.
* Fixed darkening of the image when alpha or material id tracer are used with a generated aperture.
* Added reporting of CUDA and OpenCL driver version(s)
* Options dialog now warns when using "localhost" as the hostname for the Network Manager.
* When opening a material that has displacement, subdivision is added the the preview mesh.
* Fixed: When rendering with GPU acceleration and stopping, render times and SPS stats still keep updating.
* Fixed obstacle map loading for aperture diffraction.
* Fixed disappearing Render Settings widget.
* Greatly improved message handling overhead in realtime mode.
* Resolved minor GPU acceleration performance regression.
 Profile
Offline
I get the attached message.
It shows since 3.2.4 release.
3.2.3 works allright :)
 Profile
Offline
Site Admin
Hi Pibuz, I'm afraid you'll have to update your drivers again: http://www.nvidia.com/drivers
The 285.62 certified drivers from October work great :)
 Profile
Offline
Hi Thom.
I was quite sure I had a quite updated drivers configuration, but you were right (as always): I had 276.14, and the current is 276.28 (I'm referring to nVidia QUADRO 4000 drivers).
Once updated, the error still appears.
 Profile
Offline
Site Admin
Interestingly the latest Quadro drivers don't support CUDA 4.1, even though they are of the correct version number and very recent etc.
Sorry for this inconvenience and thanks for reporting, we'll revert to 4.0 for now.
 Profile
Offline
BiDir + MLT is broken ?
I tried to render a simple test scene and it said 0 s/s despite using all cores.
EDIT: appears to be related to using an SSS material.
 Profile
Offline
Site Admin
SSS materials can induce a very high number of scatters, which makes the MLT warmup take a loooong time. There's also a case where it can become essentially stuck, this is known and will be fixed relatively soon (it's on our TODO towards the top!).
 Profile
Offline
If you trigger image overlay options during rendertime, the "Time elapse" counter resets to Zero...
There is a very ugly bug regarding EP and Glass material (rendertime varies!):
EP activated in BiDirPT:
No EP in BiDirPT:
EP activated in BiDirMLT:
No EP in BiDirMLT:
For me it looks liuke behind the glass you only see sky light but not direct Sunlight in PT mode, same as the Bug reported before GPU + EP.
Any thoughts here guys? I used the old Sky Model and no, Glass Acel. doesn't help here :(
** EDIT **
Attached Szenefile
EP Bug.pigs [2.79 KiB]
Downloaded 39 times
 Profile
Offline
I also did a quick test with that scene using a EnvMap,
here you have a small shift ind the EnvMap, but no actual rendering issues:
EP active:
Ep off:
 Profile
Offline
Arthur, you are great reminder. Thanks, i posted this few months back and i hope this will be fixed soon.
 Profile
Offline
Site Admin
Hi Zom-B,
Thanks for the report.
It's not actually a bug, just the same old slow-to-converge behaviour with some kind of paths.
I do have some plans to fix this.
 Profile
Offline
What's an EP?
 Profile
Offline
Exit Portal I guess.
Took me some time to figure it out too :D
 Profile
Offline
OnoSendai wrote:
Hi Zom-B,
I found this "bug" at begninning of summer as far as i remember and i did some tests. One of them was rendertime. 48hours on 2 computers and sun wasnt visible behind the glass. Without EP, sun is visible immediately.
 Profile
Offline
It seems that GPU rendering has a general darker phong material then CPU based rendering:
CPU:
GPU:
Something that can be fixed?
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
