Indigo Renderer 3.2.3
Post by OnoSendai » Wed Nov 30, 2011 5:28 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.2.3_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.2.3_Setup.exe
IndigoRenderer3.2.3.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.2.3_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.2.3_Setup.exe
IndigoRT3.2.3.dmg
Changelog:
3.2.3
* Updated OpenCL kernels to be more conformant with OpenCL 1.0 (1.1 not strictly required)
* Fixed reporting of CUDA and OpenCL clock speeds
* Sped up initialisation of OpenCL
* Sped up SSS for CPU single dir path tracing.
* Fix mem leak when restarting render in GPU path tracing mode. (e.g. on displacement change)
* fixed save and save as buttons when extension is in upper case
* Included SkIndigo installer updated to SkIndigo 3.2.2 installer.
* Fixed black ring around sun in bidir.
* Fixed crash with aperture diffraction in some cases.
* Made CPU path tracing significantly faster.
* Added ground to new sky model.
* Indigo and Indigo RT now show up in control panel
* Fixed some ISL bugs.
* Added SunSkyControl for changing the sun/sky in realtime.
* Updated blendigo installer to blendigo-2.5-3.2.2.0
* Fixed network rendering bug with DiscoveryPacketListener.
* Fixed display of scene metadata in GUI.
* Fixed updating of camera UI when camera state changes.
* fixed "show materials folder"
Re: Indigo Renderer 3.2.3
Post by CTZn » Wed Nov 30, 2011 5:36 am
It's a lovely changes log !
Stinkie
Post by Stinkie » Wed Nov 30, 2011 7:29 am
It is. :)
Post by Pibuz » Wed Nov 30, 2011 8:13 am
Cool! Thanks!
One question (just tested): have you guys a little time to fix the materials' alpha map not being rendered correctly in alpha render mode? It's a little boring to manually defringe all the trees :P
Post by pixie » Wed Nov 30, 2011 8:48 am
So much goodies in such a small box!
Post by CTZn » Wed Nov 30, 2011 9:29 am
Pibuz wrote:One question (just tested): have you guys a little time to fix [...]
concave faces ?
Post by OnoSendai » Wed Nov 30, 2011 9:43 am
Pibuz wrote:Cool! Thanks!
Hi Pibuz,
I will add this one to the TODO list.
Post by Pibuz » Wed Nov 30, 2011 9:46 am
Thanks a lot!
ENSLAVER
Post by ENSLAVER » Wed Nov 30, 2011 2:55 pm
Nice update :D
What's the "Extra Atmospheric" tick box do?
Post by CTZn » Wed Nov 30, 2011 7:37 pm
Action wich excludes the sky layer from rendering (for space and custom atmospheres situations). I guess that's the naming you are not used to !
ENSLAVER
Post by ENSLAVER » Wed Nov 30, 2011 7:43 pm
CTZn wrote:Action wich excludes the sky layer from rendering (for space and custom atmospheres situations). I guess that's the naming you are not used to !
Ha, yeah I figured it was for something like that, just making sure. I see how the naming works now, like extra terrestrial =P
Post by Zom-B » Wed Nov 30, 2011 8:07 pm
Hey guys...
It seems there is something fishy about this version!
First of all the OpenCL 1.0 compatibility should make my ATI 4870 work...
Well, rendering with enabling it starts and does produce a Rendering... but GPU utilization is @ 1% what tells me that the CPU still does the work here!
Maybe some other OpenCL 1.0 people can tell confirm...?!
Second thing was to test general speed... yeah :)
My first very simple testscene jumped from 653k to 725k from last to this version... awesome!!
But then I realized that the new version doesn't refresh Viweport after hitting the halt condition O_o
By this I wasn't able to save my 2min rendering for comparing with old version since last refresh was at 1min... wtf!!?!
Then I did further speed tests and had some quite catastrophically bad results with my Kitchen & Cinema scene:
Kitchen PT-BiDir:
3.2.2: 259k
3.2.3: 170k
Kitchen PT:
3.2.2: 288k
3.2.3: 215k
Cinema (SSS) PT-BiDir:
3.2.2: 325k
3.2.3: 251k
Bedroom II PT:
3.2.2: 404k
3.2.3: 406k
Grass PT:
3.2.2: 217k
3.2.3: 226k
juan_irender
Post by juan_irender » Wed Nov 30, 2011 10:46 pm
Hi Zom-B.
Yes, I can confirm I have obtain same s/s in path tracing (CPU) and GPU accelerated path tracing, seems CPU are doing all the work in OPEN CL mode too.
My OS is OSX 10.6.8, the graphic card is a Radeon 4850.
Post by OnoSendai » Thu Dec 01, 2011 1:06 am
Zom-B wrote:Hey guys...
Kitchen PT-BiDir:
3.2.2: 259k
3.2.3: 170k
Kitchen PT:
3.2.2: 288k
3.2.3: 215k
3.2.2: 325k
3.2.3: 251k
Bedroom II PT:
3.2.2: 404k
3.2.3: 406k
Grass PT:
3.2.2: 217k
3.2.3: 226k
Hi Zom-B,
How are you measuring GPU utilisation?
Post by Zom-B » Thu Dec 01, 2011 1:34 am
Hey Ono, using GPU-Z.
