Download Trial Buy now
Log in or Sign up for the chat.
Search  | Login  | Register
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
Offline
Hi guys, In the help files for Maxingo it says:
On page 10
"The Sky is modelled on a northern hemisphere sky. Pick a TARGET LIGHT to use to set the direction of the sun.
My question is, What happens if there are not target lights on the scene. Will there still be a "Sun" ? If so, how do you control it possition?
 Profile
Offline
3rd dev
Target light is the only way to control the sun.
What do you mean there is no target light in the scene? Just add one. :)
You can get the sun to show up also without having a target light by just enabling the Sky system under Maxigo>Environment. But then the sun will be in it's default position and you can't control it.
 Profile
Offline
This "default" possition is something programed at the "factory" correct?
Does it represent a specific time? I noticed that is shines into the spaces from the "south" or bottom of the scene.
If would be very helpful to know if the default possition corresponds to any particular time or such. (as general knowlege)
 Profile
Offline
3rd dev
Well..the default sun position is random.
It doesn't represent a specific time or such.
It's just some random location I used when I was programming Maxigo.
 Profile
Offline
I see, great thank you for your active response. I will download the Sketchup plug-in but I wonder if the same applies?
 Profile
Offline
SkIndigo doesn't use a target light for the sun direction, it uses SketchUp's Shadow system to direct the sun.
 Profile
Offline
Thanks ;)
 Profile
Offline
I noticed my renders are showing a sky. I there a way to get black or white backdrop for easy compositing or just for the sake of having a white of black backdrop?
The trick is that I still need eviroment lighting and sun.
 Profile
Offline
The possibility to combine Sun Light + EnvMap is planned somewhere in the future afaik.
Until then you have the possibility to simply paint/brighten-up the sun into your EnvMap. This works quite good, but needs a little bit of testing until you get the brightness you want. this also works nicely with Exit Portals...
Otherwise this tutorial might help: viewtopic.php?f=19&t=5088
_________________
 Profile
Offline
3rd dev
You could render out an alpha and use it when compositing.
 Profile
Offline
The alpha shouldn't take the long to "cook" correct?
 Profile
Offline
yes, it should be fast!
But afaik there is a bug atm, that some materials mess around with the alpha rendering... if it does, simply try to delete them for this pass and undo after success.
_________________
 Profile
Offline
thanks ill give it a shot
 Profile
Offline
Use the 'clay render' method to get around the alpha render bug :P
 Profile
Offline
can you please elaborate? I know what a clay render is, but what so you mean the clay render method?
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
