Blendigo 2.4.x Releases
Re: Blendigo 2.4.x Releases
Post by StompinTom » Tue Aug 24, 2010 3:26 am
Thank you so much, Doug!!! Will test it as soon as I get the chance!
Post by StompinTom » Thu Aug 26, 2010 2:40 am
Small note:
When exporting particle systems with their size controlled by vertex groups/weight painting, I seem to be getting an error about the transform matrix not being invertible when there are particles with size 0. Would it be worth having Blendigo check for objects with size 0 on export and skipping them to prevent this?
dougal2
Post by dougal2 » Thu Aug 26, 2010 2:56 am
StompinTom wrote:Small note:
That sounds possible, I will have a look.
cooler_inc
Post by cooler_inc » Sat Aug 28, 2010 1:46 am
sorry for stupid question, maybe I do smth wrong, but after tuning up the materials with textures, saving and quiting blender - I open this blend file and see that materials where channel type should be set like "Texture" is set to "Colour". Why it happens?
Post by Headroom » Sat Aug 28, 2010 3:34 am
No stupid question at all.
However, if you render, the texture is still applied.
If you change "color" to "texture" you'll see that "filename" still still contains the path to the texture image.
It can be quite annoying this little bug :roll:
cooler_inc
Post by cooler_inc » Sat Aug 28, 2010 8:38 pm
Headroom wrote:No stupid question at all.
U r right, thx :D
|MM|
Post by |MM| » Tue Sep 07, 2010 10:05 am
How do I render hair particles (hair particle instanced objects).
Is it impossible or am I missing something?
I could render only the emitter type.
dakiru
Post by dakiru » Tue Sep 07, 2010 10:36 pm
|MM| wrote:How do I render hair particles (hair particle instanced objects).
As far as I know it's not possible yet. But you can use emitter particle system to achieve the needed effect and particles should be meshes.
dag
Post by dag » Wed Sep 15, 2010 5:28 am
Get the same runtime error when starting blendigo as with LuxBlend, but stuff works. You develop both?
Upgraded 2.4.5 > 2.4.8
dougal2
Post by dougal2 » Wed Sep 15, 2010 8:15 am
dag wrote:Get the same runtime error when starting blendigo as with LuxBlend, but stuff works. You develop both?
What error exactly? I've seen quite a few different ones over the last few months :lol:
dag
Post by dag » Wed Sep 15, 2010 2:03 pm
http://www.luxrender.net/forum/viewtopi ... =11&t=3205
Using 64 bit blender. Blendigo installed in C:\Program Files\Blender Foundation\Blender\.blender\scripts
dougal2
Post by dougal2 » Thu Sep 16, 2010 5:59 am
dag wrote:http://www.luxrender.net/forum/viewtopi ... =11&t=3205
You really could try to provide some specific details of your system. However, having read through that LuxRender thread the problem was found to be the use of the socket python library with regards to materials database integration and 64-bit windows environments.
Blendigo should in fact disable that part of the code on windows 64 bit (and has done so for quite a while now), and indeed everything works for me using a 64bit windows setup. (In fact, I do most blendigo development using 64bit win, 64bit blender and 64bit python installed).
Now for the boring questions.... which version of blendigo do you have installed? Which version(s) (if any) of python do you have installed? Which release of blender are you using (official 64bit 2.49b?) ?
dougal2
Post by dougal2 » Thu Sep 16, 2010 6:13 am
New feature coming really really soon.... (right click the image, press play ;) )
(particle instance motion blur)
dakiru
Post by dakiru » Thu Sep 16, 2010 6:59 am
dougal2, this rocks! Great work 8)
dag
Post by dag » Thu Sep 16, 2010 9:51 am
dougal2 wrote: Now for the boring questions.... which version of blendigo do you have installed? Which version(s) (if any) of python do you have installed? Which release of blender are you using (official 64bit 2.49b?) ?
Using blendigo 2.4.10 now. All I've done is upgrade blendigo.
Most likely installed blender 2.49b 32 bit in C:\Program Files\Blender Foundation\Blender then overwrote with the 64 bit files since there is no installer for it.
Python 2.6.1 64 bit.
Win 7 ultimate 64 bit.
Compiled with Python version 2.6.1.
Checking for installed Python... got it!
BLENDIGO v2.4.10
  Platform             : post2008Server 6.1.7600  Multiprocessor Free
  os.sep               : \
  Indigo path          : C:\Program Files\Indigo Renderer\indigo.exe
  matdbPreviews        : C:\Program Files\Blender Foundation\Blender\.blender\sc
ripts\blendigopkg\matdb\previews
  assetsPath           : C:\Program Files\Blender Foundation\Blender\.blender\sc
ripts\blendigopkg\assets
  matdbDownloads       : C:\Program Files\Blender Foundation\Blender\.blender\sc
Talking about particles... why won't they emit light? Group visualization. Only the source object emits light. Particles render with the same material but without light emission.
