error message
error message
in max8 i'm getting an error MaxScript Macroscript error exception --No ""*"" function for undefined
Any ideas what may be causing this - cheers
Hello skook,
welcome to the forum! Some quick questions ...
1. Did you follow the readme to properly install the script?
2. Did you edit the m2i.ini to specify the directory of Indigo?
3. When does this error occur?
4. What does your scene look like?
5. What lighting do you use?
6. What shaders do you use?
Don't worry we'll get it to work somehow ... hehe. ;o)
take care
psor
take care
psor
"The sleeper must awaken"
this is the message it gives:
Welcome to MAXScript.
-- Error occurred in anonymous codeblock
-- Defined in encrypted script
-- Error occurred during fileIn in <File:C:\Program Files\Autodesk\3dsMax8\scripts\Max2Indigo\MAX2INDIGO0.615.mse>
-- called in execute(); filename: C:\Program Files\Autodesk\3dsMax8\scripts\Max2Indigo\MAX2INDIGO0.615.mse; position: 89454
-- called in anonymous codeblock
-- Frame:
>> MAXScript MacroScript Error Exception: -- No ""*"" function for undefined
-- Frame:
it's v0.615; it's not doing that error any more. now i get to see the render ui options, but when i go to render it says in the dos window
Fatal error: sceneloaderexcep: failed to load xml doc from path '1' failed to open file line 0, column 0.
and when i uncheck the default xml - i get
>> MAXScript Rollout Handler Exception: -- Runtime error: File not open. No I/O allowed: C:\indigo/defaultgeom.xml <<
[/img]
[/img]
Nope, looks perfect. Just another question. You are using Indigo v0.6 test6 right? ;o)
take care
psor
take care
psor
Users browsing this forum: No registered users and 67 guests
