Hello guys, and congratulations for the community
I'm starting using Indigo (first i tried MtI, and now I'm launching from max using Maxigo).
Can you help me to learn the process to light and scene using a IES file?
May I use an emitting geometry? or just a null with a ies attached?
I'm lost in this field.
Thank you very much
IES lighting files. How?
As I understand, I must create a Photometric light in Max, select a web template (i.e. Stadium 1000w Lamp - web), and load the ies file from the indigo installation folder under the Distribution (Photometric Web) tab. Isn't it?
Doing so, I only get a black render with a tiny white point where the lamp is.
May I select something in the indigo panel to tell indigo to render photometric max lights?
Did I forget doing something?
Thank you for your quick reply.
Users browsing this forum: No registered users and 85 guests
