IndigoMax 0.4.1
9 posts • Page 1 of 1
subpixel
IndigoMax 0.4.1
Post by subpixel » Tue Dec 01, 2015 7:31 pm
Hello all,
Here's a small update for IndigoMax.
Changes:
  • Done: Updated to IndigoSDK 3.8.26
  • Added: Initial version of Indigo camera
  • Added: Compilation for 3dsmax 2016
  • Fixed: Dependency load issue, which manifested in Wrappers.dll warning
Download:
IndigoMax 0.4.1
IndigoMax RT 0.4.1
Notes:
Versions: max2011 / 2012 / 2013 / 2014 / 2015 / 2016 64bit.
Hope for some comments, suggestions and descriptive bug reports. Please post them in this thread or send PM.
vasco
Re: IndigoMax 0.4.1
Post by vasco » Sun Dec 13, 2015 8:07 am
Hello,
got a problem with the material editor, max crashes when I try to create an Indigo material.
I'm working with 3ds max 2016 64bit.
subpixel
Re: IndigoMax 0.4.1
Post by subpixel » Sun Dec 13, 2015 8:38 am
Hello Vasco,
I cannot reproduce it here. Could you describe your steps to reproduce crash, please?
Thank you.
vasco
Re: IndigoMax 0.4.1
Post by vasco » Sun Dec 13, 2015 9:04 am
Hello subpixel,
the first time I tried indigoMax I had no problem, then I started testing a bit with a simple scene with a box and a teapot and changed the evironment settings. Then, when I opened the material editor and tried to create a new material max crashed. Now max crashes every time when I try to work with the material editor, but this problem only occurs when I have Indigo as renderengine enabled. Tried to reinstall IndigoMax but that didn´t solve the problem.
Last time when 3ds max crashed, it created a dump file. Will it help when I upload it for you?
edit: Do not know what I have done, played around a bit and now it seems to work again. :)
subpixel
Re: IndigoMax 0.4.1
Post by subpixel » Mon Dec 14, 2015 1:11 pm
Hello Vasco,
That sounds suspicious. May I ask you to PM me with dump file? I will have a look into it. Thank you for your help.
vasco
Re: IndigoMax 0.4.1
Post by vasco » Mon Dec 14, 2015 10:35 pm
I am sorry but it seems that my temp folder was deleted. But next time max crashes I will send a PM.
Jay-ko
Re: IndigoMax 0.4.1
Post by Jay-ko » Tue Feb 07, 2017 11:37 pm
I think that I have obtain the same kind of error one time.... let me explain:
users\xxxx\Appdata\Roaming\Indigo Renderer\... Fills up as the thumbnails need to generate.
After a while, your C: \ drive is full of tiny .PNG.
You must empty this directory or ask to 3ds Max to not use Indigo renderer to do the materials thumbnails.
That means quicker speed to open the material editor BTW, but yes, the materials thumbnails are totally black.
I recommend you to use the slate material editor, forget to use this old fashion way to create material through 3ds max ;)
errare humanum est
Jay-ko
Re: IndigoMax 0.4.1
Post by Jay-ko » Wed Aug 09, 2017 3:05 am
oup's mistake... sorry about that.
Re: IndigoMax 0.4.1
Post by Oscar J » Wed Aug 09, 2017 3:08 am
Shouldn't you be posting this in a newer thread?
Users browsing this forum: No registered users and 110 guests
