Maxigo-07 v.02 (update-21.April 2007)
- Kosmokrator
THNX SUVAKAS FOR THIS RELEASE!but i always get an error msg when i hit the export button...either in 3ds format or xml....the error msg says
"--No ""skipToString"" function for undefined"
and nothing happends after this.....any ideas?
damn - I don't get this error at all
Now this will be hard one to debug since i can't produce that error.. but i'll try to search for that string stuff from my code.
You get this right after you press the export button and not before? Does it start to export something? (is there something written behind Currently Exporting line?)
Suvakas
[edit] Ok. I found the reason. Will try to fix it
Suvakas
no skiptostring function are definited
"no skiptostring function are definited" this message is a bug? how do?
- Kosmokrator
Hey Kosmo, can you send me the inifile.txt located in your Exported_From_Max directory?
Since the entire exporter directory structure gets re-created with the From instead of Fom, then also inifile is copied from your indigo installation dir to new exporter dir. It is possible, that you have messed up your Indigo ini. (or it is an exporter bug since i'm writing stuff from and to ini file now)
- Kosmokrator
sorry suvakas i found the problem...is the old directory from previus version of exporter!works fine!
and the fix mesh errors are superb!works very well!!!
