Hey all,
Here's new Maxigo version for Indigo 2.6.1 with Max 2012 support. You need to have Hotfix installed for Max 2012 or it will not work.
You can get the hotfix from here:
http://usa.autodesk.com/adsk/servlet/ps ... ID=9241178I also added a new feature called Archi glass acceleration (supported since Indigo ver 2.6.1)
Here's the change log:
Code:
Changes in v.2.6:
* added - Architectural Glass Acceleration parameter under "Renderer parameters" (works when BiDir mode enabled)
* fixed - Procedural textures scale
** recompiled for 3ds Max 2012 (** needs at least Hotfix 1 from Autodesk)
A know issue with Max 2012 is, that the progress bar sometimes freezes. I don't know why. Also I've only tested the build on my machine so let me know if it works for you or not.
Suv
