Blender 2.5 Alpha 0 -- Released--
- Borgleader
Blender 2.5 Alpha 0 was released by the Blender Foundation this week, you can download it here:
http://www.blender.org/download/get-25-alpha/
Files are available for Windows 32/64 bit, Linux & Mac OSX
http://www.blender.org/development/rele ... ender-250/
Here you can find a roadmap of the project and the main features of Blender 2.5.
Enjoy.
Enjoy.
Re: Blender 2.5 Alpha 0 -- Released--
Great, but I get an error when I try and run the Windows x64 version..
- Error.jpg (21.29 KiB) Viewed 9013 times
samlavoie.xyz
- Borgleader
I suggest your report it, the 32bit version is running fine on my machine.
Works fine on Win7 64 bit/AMD 6000. Currently figuring out how to the move tool works (there aren't any axis..axis?).. By default, it's in "free move" mode.
EDit : oh wow, that is cool. One move tool and 3 hotkeys for each axis.. wow, this will make for a great workflow..
neo0. wrote:Works fine on Win7 64 bit/AMD 6000. Currently figuring out how to the move tool works (there aren't any axis..axis?).. By default, it's in "free move" mode.
If you're learning blender one suggestion I have is to google any questions you may have, google was a great help for me when I was first starting Blender.
samlavoie.xyz
- Doug Armand
Hmm well it doesn't have import for .obj files and I can't seem to work out how to use scripts like Indigo?
Interface looks 'prettier' though
Doug
Doug Armand
Doug Armand
- Polinalkrimizei
Godzilla, are you using the latest python? 2.5 64bit doesnt't work with python 2.6
I had to uninstall the old python, now it works like a charm
I don't even know what python is and it worked anyway. One thing though.. Their documentation is all outdated now.. they really need to get it up to speed and quickly. There are probabaly going to be a ton of people nabbing up 2.5 just for the revamped UI..
Neo0, bear in mind its still an alpha release, so updating hundreds of pages of docs so they no longer represent the current stable version would be a little hasty, i think.
- Borgleader
It has .obj import because I've used it before, in fact it was in one of the earlier builds:Doug Armand wrote:Hmm well it doesn't have import for .obj files and I can't seem to work out how to use scripts like Indigo?
File --> Import --> Wavefront (.obj)
In Blender 2.5 scripts like blendigo get added directly into the rest of the UI like normal panels, it's a seamless integration, there won't be a "Scripts Window" anymore.
http://blenderartists.org/forum/showthread.php?t=164765
Here you can find a bunch of scripts examples, if you want to try them out just copy/paste the text into the text editor and then press "Alt+P" the "tricky" part is to watch out for this line:
class OBJECT_PT_hello(ObjectButtonsPanel):
As you can see it says "Object Buttons Panel" and so to "find" that particular script menu/gui you must go to the objects tab in the properties window (between Object Constraints and World options, in the right column near the top)
Good luck and happy blending
Well, sign me up for Blendigo 2.5 beta squad then! I'm pumped to use the new Blender and it looks like it offers way more. From what I understand, external renderers can be integrated more tightly with Blender now
Let me know when you need testers!
- Doug Armand
Sounds good but after a quick play I couldn't get Blendigo to work - kept getting a python script error. Your right about .obj import though - must get my eyes tested againBorgleader wrote:It has .obj import because I've used it before, in fact it was in one of the earlier builds:Doug Armand wrote:Hmm well it doesn't have import for .obj files and I can't seem to work out how to use scripts like Indigo?
Doug
Doug Armand
Doug Armand
- Borgleader
What python script error are you getting?Doug Armand wrote:Sounds good but after a quick play I couldn't get Blendigo to work - kept getting a python script error. Your right about .obj import though - must get my eyes tested again
Dumb question, but I can't find how to switch from face selection to edge selection..
- Doug Armand
This one. which refers to this line?Borgleader wrote:What python script error are you getting?Doug Armand wrote:Sounds good but after a quick play I couldn't get Blendigo to work - kept getting a python script error. Your right about .obj import though - must get my eyes tested again
modulesPath = os.path.join(Blender.Get(u"scriptsdir"), "blendigopkg")
I have placed the blendigopkg folder in the scripts directory
Doug
Doug Armand
Doug Armand
