Request: Save as Photoshop
7 posts • Page 1 of 1
forgeflow
Post by forgeflow » Mon Apr 12, 2010 4:17 pm
It would be nice to be able to save the rendered image as a 32bit photoshop file, with each light group in a separate layer.
Re: Request: Save as Photoshop
Post by fused » Mon Apr 12, 2010 5:28 pm
agreed.
but what about a photoshop plugin that reads igi files? i remember i looked into that a little while ago but I didnt follow it any further. It definitely is possible.
Post by Zom-B » Mon Apr 12, 2010 8:22 pm
Yes, a quite old request ^^
A IGI import Plugin for PS with lightLayer Support would be more interesting ;-)
Afaik the structure for PhotoShop and AfterEffects is quite similar, so having both wouldn't be to much extra work...
Soup
Post by Soup » Fri Apr 16, 2010 9:24 am
What a nice idea, +1!
Post by StompinTom » Fri Apr 16, 2010 10:56 am
Lightlayers + alpha map?
Post by StompinTom » Fri May 07, 2010 5:01 am
In the same vein, it would be very helpful to put in Indigo tonemapping as a Photoshop plugin as well, to get from the 32-bit raw files to an 8-bit image. You could also use it for any HDRIs in that case...
On the other hand, isn't this functionality the type of thing that Violet would do?
Post by Zom-B » Fri May 07, 2010 7:17 am
StompinTom wrote:In the same vein, it would be very helpful to put in Indigo tonemapping as a Photoshop plugin as well, to get from the 32-bit raw files to an 8-bit image. You could also use it for any HDRIs in that case...
Interesting point! I don't think tonemapping, post-aperture-difraction etc. are saved in the igi file anyway!!!
StompinTom wrote:On the other hand, isn't this functionality the type of thing that Violet would do?
integration into the actual PS based workflow without multiple single image save actions in indigo or Violet is the point here! open igi file, all light layers and alpha are on a own named layer!
